No successful CAN bus sending with NucleoG474RE
That is cool. I remembered something. Your board is not contain standard CAN controller but FDCAN controller, which was first time implemented into can_api with STM32H7. So maybe there can be an issue for extended id.
However, from my point of view, if you are trying to solve a problem, it would be good to try that with the Mbed CAN api example. It could be used on one board with CAN-bus loop back between both CAN controllers. If that will work, then you can use it again on two different boards and so on.
