I am trying to turn on the built-in LED by register of NUCLEO-F103RB.
I referred to datasheet and reference manual.
But LED didn’t turn on.
My code is below.
Help me plz.
#include “mbed.h”
(*(volatile unsigned )0x40021018) |= 0x4; // active
( (volatile unsigned )0x40010800) |= 0xFFFFFF0F;
( (volatile unsigned *)0x40010800) |= 0x900000;
hudakz
(Zoltan Hudak)
July 14, 2021, 5:07pm
2
Hello Lee,
Before writing to a GPIO we should initialize the related port and pin (Pin 5 of Port A in this case):
Enable GPIO clock.
Fill GPIO object structure.
Set pin mode.
Configure internal pull resistor.
#include "stm32f1xx_ll_gpio.h"
#include "pin_device.h"
gpio_t led_gpio;
extern const uint32_t ll_pin_defines[16];
extern "C" GPIO_TypeDef *Set_GPIO_Clock(uint32_t port_idx);
// Enable GPIO clock
GPIO_TypeDef *gpio = Set_GPIO_Clock(PortA);
// Fill GPIO object structure
led_gpio.mask = (uint32_t)(1 << (uint32_t)(0x05) & 0xF); // pin 5
led_gpio.gpio = gpio;
led_gpio.ll_pin = ll_pin_defines[((uint32_t)(0x05) & 0xF)]; // pin 5
led_gpio.reg_in = &gpio->IDR;
led_gpio.reg_set = &gpio->BSRR;
led_gpio.reg_clr = &gpio->BRR;
// Set pin mode
register uint32_t *pReg = (uint32_t *)((uint32_t)((uint32_t)(&led_gpio.gpio->CRL) + (led_gpio.ll_pin >> 24)));
MODIFY_REG(*pReg, ((GPIO_CRL_CNF0 | GPIO_CRL_MODE0) << (POSITION_VAL(led_gpio.ll_pin) * 4U)), (LL_GPIO_MODE_OUTPUT << (POSITION_VAL(led_gpio.ll_pin) * 4U)));
// Configure internal pull resistor.
// Default is GPIO_NOPULL so no action is needed.
// Turn on the LED (GPIO PA_5).
*led_gpio.reg_set = led_gpio.mask;
return 0;
