I am trying to connect to SERIAL2_RX/SERIAL2_TX on a NUCLEO-F303K8 board via RS232 using an RS232 to TTL level shifter instead of the built-in USB to Serial connection. Transmitting on Pin A7 (PA_2) works as expected but data coming to Pin D12 (PB_4) is not recognized.
I have verified the hardware with a scope and If I switch the hardware to use SERIAL1 on pins D4/D5, everything works as expected. Is there possibly a known conflict with the built-in USB to serial bridge?
Ahoj,
according to board’s user manual, the default pins which are used for the ST-Link VCP are PA2 and PA15. Where PA15 is not connected to any pin of standart arduino header.
I have not been able to test it yet. When I try to add a mbed_app.json file to the online compiler, it parses the file but it does not appear to have any affect on the code. I assume this is because my project is using the pre-built mbed library. I can’t include the mbed-dev library with the online compiler because of a size restriction/bug.
I then tried to switch to the cli environment but I can’t get the mbed-dev library to download (it just times out). I have searched the forums and it appears to be a common problem that they are working on.
If you have any suggestions on an easy way to test, I would appreciate it. My trivial test program is here: <<program /users/ChrisABailey/code/Nucleo_Serial_test/>>
