Hi all,
I’m new mbedtls and these forums, so I apologize if this is the wrong place for this!!
I’m trying to parse a 3072 bit rsa private key on an esp32 with the following code.
int ret = 0;
size_t olen = 0;
char buff[128];
unsigned char result[MBEDTLS_MPI_MAX_SIZE];
unsigned int challenge_bin;
const char *pers = "mbedtls_pk_decrypt";
mbedtls_ssl_context ssl;
mbedtls_pk_context pk;
mbedtls_ssl_config conf;
mbedtls_ssl_init( &ssl );
mbedtls_ssl_config_init( &conf );
mbedtls_entropy_init(&entropy);
mbedtls_pk_init(&pk);
mbedtls_ctr_drbg_init( &ctr_drbg );
memset(result, 0, sizeof(result));
extern const unsigned char prvtkey_pem_start[] asm("_binary_key5fdbe1ce8e_pem_start");
extern const unsigned char prvtkey_pem_end[] asm("_binary_key5fdbe1ce8e_pem_end");
const unsigned int prvtkey_pem_bytes = prvtkey_pem_end - prvtkey_pem_start;
* Parse Challenge Token
cJSON * json = cJSON_Parse(challenge);
char * encrypted_token = cJSON_GetObjectItem(json, "challenge_token")->valuestring;
printf("%s\n", encrypted_token);
cJSON_Delete(json);
//challenge_bin = htoi(encrypted_token);
* Read the RSA privatekey
printf("\nSeeding the random number generator..." );
ret = mbedtls_ctr_drbg_seed(&ctr_drbg, mbedtls_entropy_func, &entropy,
(const unsigned char*)pers, strlen(pers));
if( ret != 0 ) {
char buff[128];
getTlsError(ret,buff,sizeof(buff));
fprintf(stderr, "\nSeeding random number has failed, error=0x%04x, msg=%s", ret, buff);
char buffer[prvtkey_pem_bytes + 1];
memcpy(buffer, prvtkey_pem_start, prvtkey_pem_bytes);
buffer[prvtkey_pem_bytes + 1] = '\0';
printf("\n%s\n", buffer);
ret = mbedtls_pk_parse_key(&pk, (const unsigned char *) buffer, (prvtkey_pem_bytes + 1), NULL, 0 );
if( ret != 0 ) {
fprintf(stderr, "\nPrivate key parsing has failed, error=0x%04x, msg=%s", ret, buff);
By itself, I get no error codes and everything seems to be peachy. However, the moment I start to try and decrypt my challenge token, with this code.
* Decrypt the token.
printf( "\nGenerating the encrypted value" );
ret = mbedtls_pk_decrypt(&pk, (unsigned char *)encrypted_token, sizeof(encrypted_token), result, &olen, sizeof(result), mbedtls_ctr_drbg_random, &ctr_drbg);
if( ret != 0 ) {
getTlsError(ret, buff,sizeof(buff));
fprintf(stderr, "\nPrivate key decryption has failed, error=0x%04x, msg=%s", ret, buff);
//printf("\nDecrypted Token: %s\n", result);
Not only do i not get my decrypted result, I start getting errors with the parsing of the key…
Private key parsing has failed, error=0xffffc300, msg=PK - Invalid key tag or value
Any idea whats going on her? Am i doing anything blatantly wrong or misunderstanding something? It’s worth mentioning that i’ve changed MBEDTLS_MPI_MAX_SIZE to a suitably large default.
Any advice or thoughts are massively appreciated.
Spencer
