Hi I’m trying to port a project from an L053R8 to a L432KC board, which makes use of an SD card over SPI. While trying to select the proper pins on L432KC I decided for the SP1 on PA_6, PA_5, PA_4, PB_5, for mosi, miso, sclk, cs respectively, after opening the SB16 and SB18 bridges. Apparently, either I disable the built-in LED (which overlaps with SPI3 CLK), or I open those bridges to use SPI1. Am I right?
Compilation is fine, both on MBed2 (the original project version) and on Mbed 5.
But, in both cases at run time, right during system init, I get this message “pinmap not found for peripheral”. Below the serial out from the MBed5 build:
++ MbedOS Error Info ++
Error Status: 0x80010130 Code: 304 Module: 1
Error Message: pinmap not found for peripheral
Error Value: 0x6
This is the SD definition I use with MBed 2:
SDFileSystem sd(PA_6, PA_5, PA_4, PB_5, "sd"); // mosi, miso, sclk, cs
this is the one on MBed 5.19.2:
SDBlockDevice sd(PA_6, PA_5, PA_4, PB_5); // mosi, miso, sclk, cs
What’s wrong, with it?
Note, hardware wise it should be ok, as the ‘mbes-os-example-blinky’ starts just fine.
These are some old posts I’ve reviewed already (no help, unfortunately):
https://os.mbed.com/questions/79508/Conflict-between-serial-port-and-spi-on-/
https://os.mbed.com/questions/83057/SPI-master-and-slave-at-the-same-time-NU/
https://os.mbed.com/questions/84498/Getting-error-Pinmap-not-found-for-SPI-u/
Thanks
