but I get this error Identifier “nulptr” is undentified serial stream(serialclass_&_serialclass , const char*name =nullptr)"
is there something I can do here to fix this code or is there any other way to print on serial
The source seems to be from here - SerialStream - Bringing MBed serial ports back like it’s 1999…… | Mbed, but I cannot reproduce your issue - tested with Nucleo-F767ZI, MbedOS 6.15.1 under KeilStudio.
However, the error probably comes from constructor of SerialStream, which is not used in this code, so try to run CleanBuild, and the #include "SerialStream.h" in the context of this code is also pointless.
thank you for your reply , at first I was compiling with mbed online compiler but I tried it with the online KeilStudio like you and it worked ,and i used putty serial and started printing messages yeahh
