kiskovce2
(kisko mravcik)
March 29, 2021, 9:26am
#1
Hi there,
I would like to ask for best practice how it shall be use non-volatile data.
For example, keep data of integer or array type after reset.
I found way how to create txt file in USB mass storage, but this is quite overengineered solution, I think so.
Any idea for rookies like me ?
Thanks a lot.
MK.
cjost
(Chris Jost)
March 29, 2021, 9:42am
#2
Just as an idea, most STM32 devices I know have backup registers that are kept as long as V_BAT is on. However there are not many registers usually. They can be found in the reference manuals under the tamper sections.
Best,
Chris
JohnnyK
(Jan Kamidra)
March 29, 2021, 9:50am
#3
use SD card or if you want it without external hardware try this - KVStore - API references and tutorials | Mbed OS 6 Documentation
kiskovce2
(kisko mravcik)
March 29, 2021, 10:23am
#4
Thanks a lot.
is there any simpler than 200line example for KVStore?
MK
JohnnyK
(Jan Kamidra)
March 29, 2021, 3:52pm
#5
I don’t know about something official.
But you can try a simple code below.
For example click HERE
#include "mbed.h" //MbedOS 6.9 Nucleo-F303RE
#include "KVStore.h"
#include "kvstore_global_api.h"
#include <string>
/*A serial monitor is required (tested with Termite 3.4)*/
#define DEBUG 1
debug_if(DEBUG, "Hello from Mbed OS version %d.%d.%d\n\n", MBED_MAJOR_VERSION, MBED_MINOR_VERSION, MBED_PATCH_VERSION);
thread_sleep_for(500);
char str[5];
char kv_key[] = {"/kv/key"};
char kv_value[5];
kv_info_t info;
while(true){
debug_if(DEBUG, "Please, enter a value! - five-digit \n");
scanf("%5s",str);
debug_if(DEBUG, "Your value is %s!\n", str);
kv_get_info(kv_key, &info);
kv_get(kv_key, kv_value, info.size, 0);
bool check = true;
for(int i=0;str[i]!='\0';i++){
if(str[i]!=kv_value[i]) check = false;
if(check){
debug_if(DEBUG, "This value is already stored!\n");
}else{
debug_if(DEBUG, "Saving new value\n");
kv_set(kv_key, str, strlen(str), 0);
