I’m trying to connect a GUI interface on a Raspberry pi 3 (Sliders and buttons) to control output and show input from an STM F303k8. I understand the protocol of I2c but don’t know how to find the address of the STM. Also, I don’t know the syntax for setting the STM as a slave and RPI as a master. If someone could help me with syntax and finding the address of my device it would be much appreciated.
It seems when I connect my STM to the RPI via SCL and SDA lines there is no initiation and the I2Cdetect command on the RPI doesn’t pick up on the STM connection.
I had a similar problem with my current project. I wanted to connect a PC/Raspberry Pi to a STM32F303RE. It is a robot application and I considered UART serial, I2C, SPI and CANbus.
In the end I decided on UART serial. It may be the oldest of the low speed busses, but it is near universal and I have been running it at 250000 bits per second from a laptop with no problems (also works fine at 460800). These speeds match standard I2C speeds.
Where possible, I like to run protocols based on ASCII strings which makes debugging much, much easier.
