Reading variables from a local file
Dear Jan,
I created a file called setup.txt on the mbed local file and I save these variable to it:
ip 192.168.3.60
name Pin
I want to retrieve these variable from the file each time the mbed restarted , that’s mean when I change anything in the file , my variable in my program will change in the next reset.
I tried reading from the local file system but it didn’t work.
Could you please provide me with an example for the same variables I need.
Nada
I do not know what exactly did you tried but
LocalFileSystem - The LocalFileSystem is a symbiotic file system that connects to the Mbed board’s interface chip if the interface chip has built-in storage. The features available on the LocalFileSystem is dependent on the board’s interface chip. Note: The LocalFileSystem is only available on the LPC1768 and LPC11U24.
Do you still using MbedOS 5.15?
Try to look to the KVStore - APIs | Mbed OS 5 Documentation instead.
Hello Jan,
I’m trying this
LocalFileSystem local("local");   //File System
    char ip_address[15];
    char name[15];
  // update config file
    FILE * fp = fopen("/local/config.txt", "w");  // Open "config.txt" on the local file system for writing
    FILE *tmp = fopen("/local/tmp.txt", "r");  // Open "temp.txt" on the local file system for read
    if (tmp == NULL) {
        error("Could not open file");
    while (!feof(tmp)) {
        int n = fscanf(tmp, "%s\t%s\n",
            &ip_address, &name);
        if (n != 2) {
            error("Could not read 12 elements");
        fprintf(fp, "%s\t%s\n",
            ip_address, name);
    fclose(fp);
    fclose(tmp);
But I have issue with config.txt it showing me errors when I tried to open it.
Yes I’m still using mbed_os 5
in the remp.txt I wrote
192.168.3.60 Pinning
Nada
And your board is?
Lpc1768 later I will try it in the UBLOx c027
Thank you Jan,
It’s working now.
Nada
I do not have LPC1768 so can not test on real hardware. Also I not see anything wrong in your code.
But anyway I think it is waste of time. C027 is based on LPC1768 but the LPC1768 board has a addition IC memory for that feature. So do you are sure C027 also has it?
Actually I’m not sure.
I thought as UBLOX is based on the LPC1768 so it will work.
I will try and see.
Thank you so much
Nada
For Ublox do no forgot to add to mbed_app.json content below
    "target_overrides": {
            "target.device_has_add": ["LOCALFILESYSTEM"]
Thank you Jan,
Should I create this file manually?
I need also to ask you if I can assign a value to the MAC default value in the platforms- sources - mbed_interface.c from a file or xml file.?
Please, your advise
Nada
If you have access to the memory via USB, then probably yes.
I do not know it depends when the function for setting a MAC is called.
Thank you Jan.
I will try and see.
Nada
Hello Jan how are you
I had a program to creat an xml and then parse the data. I edited the program to be as the following
#include "tinyxml.h"
#include <string>
//See http://www.grinninglizard.com/tinyxml/ for more information on how to use tinyxml.
//See TINYXML Library for license.
//TODO Document library and app in embed style.
DigitalOut myled(LED1);
    //Setup Tx, Rx.
    Serial usb(USBTX, USBRX);
    usb.baud(115200);
    // Create the local filesystem under the name "local".
    // DO NOT FORGET THIS CALL OR SAVING WON'T WORK!
    // Create some Xml to experiment on.
   /* const char* demoStart =
        "<?xml version=\"1.0\"  standalone='no' >\r\n"
        "<!-- Our to do list data -->\r\n"
        "<ToDo>\r\n"
        "<!-- Do I need a secure PDA? -->\r\n"
        "<Item priority=\"1\" distance='close'> Go to the <bold>Toy store!</bold></Item>\r\n"
        "<Item priority=\"2\" distance='none'> Do bills   </Item>\r\n"
        "<Item priority=\"2\" distance='far &amp; back'> Look for Evil Dinosaurs! </Item>\r\n"
        "</ToDo>\r\n";*/
    FILE *fp = fopen("/local/demotest.xml", "r");
    char buffer[128];
    char* demoStart = new char[200] ;
    while(fgets(buffer, 128, fp))
    //memcpy(demoStart,buffer,sizeof(buffer));
        strcat(demoStart,buffer);
    //usb.printf("demostart,%s\n\r",demoStart);
        /*"<?xml version=\"1.0\"  standalone='no' >\r\n"
        "<!-- Our Pinning Station Data -->\r\n"
        "<Data>\r\n"
        "<Item  ip_address=1 > 192.168.3.80 </Item>\r\n"
        "<Item Name_P =1> Pinning_001 </Item>\r\n"
        "</Data>\r\n";*/
    // Load Xml into a XmlDocument.
    TiXmlDocument doc("/local/demotest_1.xml");
    //doc.LoadFile("/local/demotest.xml");
    /*usb.printf("Printing XML:\r\n");
    TiXmlPrinter printer;
    printer.SetLineBreak("\r\n"); //Default is "\n".
    doc.Accept(&printer);
    usb.printf("%s\r\n", printer.CStr());
    const char* demoStart = printer.CStr();*/
    // Parse Xml.
    doc.Parse(demoStart);
    // Get the tagname of the Root Element (ToDo).
    // Note: doc.RootElement()->Value().c_str() is not compatible with printf! E153
    string tag = doc.RootElement()->Value();
    usb.printf("RootElement = <%s>\r\n\r\n", tag.c_str());
    // Iterate Elements with for loop.
    usb.printf("Enumerating Item Child Tags:\r\n");
    for (TiXmlNode* child = doc.RootElement()->FirstChild(); child; child = child->NextSibling() ) {
        if (child->Type()==TiXmlNode::TINYXML_ELEMENT) {
            tag = child->Value();
            //usb.printf(child->Value());
            usb.printf("  Child = <%s>\r\n", tag.c_str());
            usb.printf("  Text  = '%s'\r\n\r\n", child->ToElement()->GetText());
            string b= child->ToElement()->GetText();
            if (strcmp(child->ToElement()->GetText(), "Pinning_001") == 0)
                usb.printf("hello\n\r");
    //Walk Elements by FirstChildElement/NextSiblingElement.
    usb.printf("Walking Item Child Tags:\r\n");
    TiXmlElement* child = doc.RootElement()->FirstChildElement("Item");
    do {
        child = child->NextSiblingElement("Item");
    } while (child);
   /* //Save to a file on the /local/ filesystem on Usb.
    usb.printf("Saving with filename:\r\n");
    doc.SaveFile("/local/out_1.xml");
    usb.printf("Saving with FILE:\r\n");
    FILE *fp = fopen("/local/out_2.xml", "w");
    doc.SaveFile(fp);
    fclose(fp);*/
    if ( doc.Error() ) {
        usb.printf( "Error in %s: %s\n", doc.Value(), doc.ErrorDesc() );
        exit( 1 );
    /*//Print the Parsed Xml.
    usb.printf("%s\r\n", printer.CStr());*/
    while (1) {
        //Wait...
I just commented the const demostart* , I wrote the const demostart* into the xml file, read the file and then copy the buffer to demostart.
When I parse the data , the result will be as the following
before commenting the demostart the result were as the following
I don’t know what the difference if I have a const char* and if I read the file and copy it to char*
Please your advise
Nada
Hello Jan, what do u mean if I have the access to the memory from the USB ???
Nada
I do not understand what you mean with the variable.
You asked about create the file manually. How did you want to create the file manually ?
I do not know how many informations do you want to hold but from my point of view the xml file seems to be like overkill solution for few strings.
Hello Jan,
I meant where I can find the mbed_app.json? if it’s not in my program path, should I create a new file and name it mbed_app.jason ?
Nada
Yes, if you not already have it in the project then you must to create new one.
Thank you just I wanted to be sure.
Nada
Hello Jan,
I hope you are doing well.
I added mbed_app.json to the my project psth on the UBLOx c_027 as te picture below:
and I wrote inside it
and I got the following error
Error: Use of undeclared identifier ‘semihost_open’ in “mbed-os/platform/source/LocalFileSystem.cpp”, Line: 107, Col: 21
when I checked the error, all the responses mentioned that the localfile is not supported in the CMSIS-DAP even after I added the json file.
Also when I wrote in the mbed_app.json the following
            "target.device_has_add": ["LOCALFILESYSTEM"],
              "target.device_has_add": ["SEMIHOST"]
I got also an error in the mbed_interface.cpp
Please your support.
Nada
and arror is?
