using NUCLE-F207ZG with Mbed os 5.15 on keil cloud (Mbed studio constinuously crashing on my W11 PC)…
I would like to receive command from a client, reply to request directly; but perform actions requested in the main Thread (meaning that I’ld like to process TCP client/server in a separate Thread.
Despite my efforst to get it works, It looks like the TCP accept or listen is bloking the entire program : I’m able to receive and respond to TCP client messages, but it looks like I never run the main loop.
Here is the code :
* Copyright (c) 2006-2020 Arm Limited and affiliates.
#undef __ARM_FP
//#define MBED_CONF_TARGET_DEFAULT_ADC_VREF 1//quick error resolution
#include "mbed.h" //MbedOS 5.15
#include "NetworkInterface.h"
#define BUFFSIZE 50
//#define ROUTER // commented = Static IP uncomented = address assigned by router
#ifndef ROUTER
#define IP "192.168.184.11" //Here place your static IP of Mbed
#define GATEWAY "0.0.0.0"
#define MASK "255.255.255.0"
#endif
#define PORT 23
DigitalOut led1(LED1);
volatile int command = 0;//semaphore
NetworkInterface *net = NetworkInterface::get_default_instance();
TCPSocket server;
TCPSocket* client;
SocketAddress clientAddress;
EventQueue queue;
char *in_buffer;
char *out_buffer;
SocketAddress ip;
Thread thread;
void tcpRoutine()
// take care of client request and reply
if(ip)
client = server.accept();
client->getpeername(&clientAddress);
const char *p_clientAddress = clientAddress.get_ip_address();
printf("Client connected from IP address: %s\n", p_clientAddress ? p_clientAddress : "None");
bool b = true;
while (b)
in_buffer = new char[BUFFSIZE];
int n = client->recv(in_buffer, BUFFSIZE);
if (n == 0) {
printf("Client disconnected\n");
b = false;
}else{
in_buffer[n-2] = '\0';
printf("Received message from Client :'%s'\n", in_buffer);
out_buffer = new char[BUFFSIZE];
n = sprintf(out_buffer,"Echo - %s", in_buffer);
//parseCommand(&command);
printf("Sending echo to client\n");
client->send(out_buffer, n);
led1 =! led1;
delete []out_buffer;
delete []in_buffer;
client->close();
else
printf("No IP\n");
net->disconnect();
//printf("Program end\n");
int main (void)
printf("TCP starting...\n");
int net_stat;
#ifndef ROUTER
net->disconnect();
net_stat = net->set_network((SocketAddress)IP,(SocketAddress)MASK,(SocketAddress)GATEWAY);
printf("set IP status: %i\n",net_stat);
#endif
net_stat = net->connect();
printf("connect status: %i\n",net_stat);
net->get_ip_address(&ip);
const char *p_ip = ip.get_ip_address();
printf("IP address: %s and Port: %d\n", p_ip ? p_ip : "None" , PORT);
SocketAddress mask;
net->get_netmask(&mask);
const char *p_mask = mask.get_ip_address();
printf("Netmask: %s\n", p_mask ? p_mask : "None");
SocketAddress gateway;
net->get_gateway(&gateway);
const char *p_gateway = gateway.get_ip_address();
printf("Gateway: %s\n", p_gateway ? p_gateway : "None");
if(ip)
server.open(net);
server.bind(PORT);
server.set_blocking(false);
//server.set_timeout(15);
server.sigio(queue.event(tcpRoutine));
//server.sigio(tcpRoutine);
server.listen(5);
printf("Server bound and listening\n");
queue.dispatch_forever();
while (1)
led1 = !led1;
printf("we are in the main loop...\r\n");
//wait_us(1000);
//ThisThread::sleep_for(10);
// main application code here
//switch(command)//
//thread.start(tcpRoutine);
Thanks in advance for any guidance
