Hi Ron,
I understand what you’re saying and my config file has MBEDTLS_FS_IO disabled. but still I can see my flash being used a lot by mbed.
I have a function in which i’m using mbedTLS functions to do a HTTPS Post and whenever I have a call to that function in my code I can see the memory being used and if I just remove the call to that function I can see that it’s not the case.
void cloud_post(void) {
mbedtls_entropy_context   entropy;
mbedtls_ctr_drbg_context  ctr_drbg;
mbedtls_x509_crt cacert;
mbedtls_ssl_config conf;
mbedtls_ssl_context ssl;
mbedtls_entropy_init(&entropy);
ret = mbedtls_entropy_add_source(&entropy, entropy_source, NULL, 128,
                                 MBEDTLS_ENTROPY_SOURCE_STRONG);
if (ret != 0) {
    printError("failed\n  ! mbedtls_entropy_add_source returned \n", ret);
mbedtls_ctr_drbg_init(&ctr_drbg);
ret =mbedtls_ctr_drbg_seed(&ctr_drbg, mbedtls_entropy_func,
                           &entropy, NULL, 0);
if (ret != 0) {
    printError("failed\n  ! mbedtls_drbg_seed returned \n", ret);
mbedtls_x509_crt_init( &cacert );
ret = mbedtls_x509_crt_parse( &cacert, (const unsigned char *)ca,
                              sizeof(ca) ); //1595
if( ret < 0 )
   printError(" failed\n  !  mbedtls_x509_crt_parse returned -0x%x\n\n", ret);
mbedtls_ssl_config_init( &conf );
ret = mbedtls_ssl_config_defaults( &conf,
                    MBEDTLS_SSL_IS_CLIENT,
                    MBEDTLS_SSL_TRANSPORT_STREAM,
                    MBEDTLS_SSL_PRESET_DEFAULT);
if (ret != 0) {
    printError("httpTask: ssl_config failed", ret);
mbedtls_ssl_conf_authmode( &conf, MBEDTLS_SSL_VERIFY_REQUIRED);
mbedtls_ssl_conf_ca_chain( &conf, &cacert, NULL );
mbedtls_ssl_conf_rng( &conf, mbedtls_ctr_drbg_random, &ctr_drbg );
mbedtls_ssl_init( &ssl );
ret = mbedtls_ssl_setup( &ssl, &conf );
if (ret != 0) {
        printError("httpTask: ssl_setup failed", ret);
ret = mbedtls_ssl_set_hostname( &ssl, "ats-2161.internal.atsclock.com" );
if (ret != 0) {
        printError("httpTask: ssl_set_hostname failed", ret);
mbedtls_ssl_set_bio(&ssl, handshake.handshakepcb, netSend, netRecv, NULL);
while ((ret = mbedtls_ssl_handshake(&ssl)) != 0) {
    if ((ret == MBEDTLS_ERR_SSL_HELLO_VERIFY_REQUIRED)) {
          * If hello verify fails, return error. Client sd needs to be
          * closed and recvfrom called again before app
          * can call startSec on the new sd
        printError("httpTask: HELLO_VERIFY_ERROR failed", ret);
    if (ret != MBEDTLS_ERR_SSL_WANT_READ
            && ret != MBEDTLS_ERR_SSL_WANT_WRITE) {
        printError("httpTask: CODE_FUNCTION_FAILED", ret);
    uint32_t flags;
    if( ( flags = mbedtls_ssl_get_verify_result( &ssl ) ) != 0 )
        char vrfy_buf[512];
        printError( " failed\n",-10 );
        mbedtls_x509_crt_verify_info( vrfy_buf, sizeof( vrfy_buf ), "  ! ", flags );
    handshake.len=0;
    handshake.previous_recv=0;
    len = sprintf( (char *) buf_request, POST_REQUEST );
    while( ( ret = mbedtls_ssl_write( &ssl, buf_request, len ) ) <= 0 )
        if( ret != MBEDTLS_ERR_SSL_WANT_READ && ret != MBEDTLS_ERR_SSL_WANT_WRITE )
            printError(" failed\n  ! mbedtls_ssl_write returned %d\n\n", ret );
    len = sprintf( (char *) buf1, SEND_FIELD1 );
    while( ( ret = mbedtls_ssl_write( &ssl, buf1, len ) ) <= 0 )
    len = sprintf( (char *) buf2, SEND_FIELD2 );
    while( ( ret = mbedtls_ssl_write( &ssl, buf2, len ) ) <= 0 )
    len = strlen(myPacket);
    while( ( ret = mbedtls_ssl_write( &ssl, (const unsigned char *)myPacket, len ) ) <= 0 )
    while(handshake.len==0)
    do
        len = sizeof( myPacket ) - 1;
        memset( myPacket, 0, sizeof( myPacket ) );
        ret = mbedtls_ssl_read( &ssl, (unsigned char *)myPacket, len );
        if( ret == MBEDTLS_ERR_SSL_WANT_READ || ret == MBEDTLS_ERR_SSL_WANT_WRITE )
            continue;
        if( ret == MBEDTLS_ERR_SSL_PEER_CLOSE_NOTIFY )
            break;
        if( ret < 0 )
            printError( "failed\n  ! mbedtls_ssl_read returned %d\n\n", ret );
            break;
        if( ret >= 0 )
            //System_printf( "\n\nEOF\n\n" );
            break;
        len = ret;
        //System_printf( " %d bytes read\n\n%s", len, (char *) myPacket );
       //get the HTTP STATUS
    while( 1 );
sscanf( myPacket, "%s %d", httpver, &status);
mbedtls_x509_crt_free( &cacert );
mbedtls_ssl_free( &ssl );
mbedtls_ssl_config_free( &conf );
mbedtls_ctr_drbg_free( &ctr_drbg );
mbedtls_entropy_free( &entropy );
this is my function and I have attached the memory allocation image as well.
In the image you can see everything in black is because of MBED and rest in blue is my code for rest of the stuff.
Do you have any idea what can be causing this?
Deepak
