Complete code added. Please let me know if I making any mistake here?
I get MBEDTLS_ERR_OID_NOT_FOUND error
Code to set the key:
int setKey(mbedtls_ecp_keypair **ec_context, const uint8_t *key_X, const uint8_t *key_Y,
const uint8_t *key, size_t key_size)
int ret = 1;
mbedtls_ecp_keypair *ctx;
if (ec_context == NULL || key_X == NULL || key_Y == NULL) {
return TEE_ERROR_GENERIC;
ctx = *ec_context;
mbedtls_ecp_group_init(&ctx->grp);
ret = mbedtls_ecp_group_load(&ctx->grp, MBEDTLS_ECP_DP_SECP384R1);
if (ret != 0) {
ret = mbedtls_mpi_read_binary(&ctx->Q.X, key_X, key_size);
if (ret != 0) {
ret = mbedtls_mpi_read_binary(&ctx->Q.Y, key_Y, key_size);
if (ret != 0) {
ret = mbedtls_mpi_lset(&ctx->Q.Z, 1);
if (ret != 0) {
ret = mbedtls_mpi_read_binary(&ctx->d, key, key_size);
if (ret != 0) {
return TEE_SUCCESS;
int GenerateCertificate(const uint8_t *public_key_X, const uint8_t *public_key_X, const uint8_t *key)
int ret = 1;
mbedtls_pk_context issuer_ctx;
mbedtls_pk_init(&issuer_ctx);
if ((ret = mbedtls_pk_setup(&issuer_ctx,mbedtls_pk_info_from_type(MBEDTLS_PK_ECKEY))) != 0) {
EMSG(" failed\n ! mbedtls_pk_setup returned -0x%04x", (unsigned int) -ret);
goto exit;
mbedtls_ecp_keypair *issuer_ecp = mbedtls_pk_ec(issuer_ctx);
res = setKey(&issuer_ecp, public_key_X, public_key_Y, private_key, 48);
if (res != TEE_SUCCESS)
goto exit;
exit:
mbedtls_pk_free(&subject_ctx);
return ret;
As the next step to generate a self signed certificate I’m using the following snippet.
TEE_Result TA_GenerateCert(void *loaded_issuer_key, void *loaded_subject_key, uint8_t **cert, size_t *len, uint8_t is_ca, const char *issuer_name, const char *subject_name)
int ret = 1;
unsigned char certificate_der[4096];
unsigned char *cert_start;
mbedtls_mpi serial;
mbedtls_x509write_cert crt;
mbedtls_pk_context *issuer_key = loaded_issuer_key,
*subject_key = loaded_subject_key;
TEE_Result res = TEE_ERROR_GENERIC;
mbedtls_x509write_crt_init(&crt);
mbedtls_mpi_init(&serial);
mbedtls_ctr_drbg_init(&ctr_drbg);
mbedtls_entropy_init(&entropy);
const char *serial_number = CERT_SERIAL_NUMBER;
if ((ret = mbedtls_mpi_read_string(&serial, 10, serial_number)) != 0) {
goto exit;
mbedtls_x509write_crt_set_subject_key(&crt, subject_key);
mbedtls_x509write_crt_set_issuer_key(&crt, issuer_key);
if ((ret = mbedtls_x509write_crt_set_subject_name(&crt, subject_name)) != 0) {
goto exit;
if ((ret = mbedtls_x509write_crt_set_issuer_name(&crt, issuer_name)) != 0) {
goto exit;
mbedtls_x509write_crt_set_version(&crt, MBEDTLS_X509_CRT_VERSION_3);
mbedtls_x509write_crt_set_md_alg(&crt, MBEDTLS_MD_SHA384);
ret = mbedtls_x509write_crt_set_serial(&crt, &serial);
if (ret != 0) {
goto exit;
const char *validity_from = CERT_VALIDITY_FROM;
const char *validity_till = CERT_VALIDITY_TILL;
ret = mbedtls_x509write_crt_set_validity(&crt, validity_from, validity_till);
if (ret != 0) {
goto exit;
if (is_ca)
ret = mbedtls_x509write_crt_set_basic_constraints(&crt, is_ca,0);
if (ret != 0) {
goto exit;
ret = mbedtls_x509write_crt_der(&crt, certificate_der, sizeof(certificate_der), mbedtls_ctr_drbg_random, &ctr_drbg);
if (ret != 0) {
return ret;
*len = ret;
cert_start = certificate_der + 4096 - *len;
cert = TEE_Malloc(*len, TEE_MALLOC_FILL_ZERO);
TEE_MemMove(cert, cert_start, *len);
res = TEE_SUCCESS;
exit:
mbedtls_x509write_crt_free(&crt);
mbedtls_mpi_free(&serial);
mbedtls_ctr_drbg_free(&ctr_drbg);
return res;
I get an error when I call mbedtls_x509write_crt_der as it returns -46/MBEDTLS_ERR_OID_NOT_FOUND( 0xffffffd2).
Am I missing anything ?
