Precursor - I’m a hardware engineer so my programming leaves a lot to be desired!
I’m having a very weird issue with MBED’s EthernetInterface and TCPSocket. I configure an EthernetInterface instance, link a TCPSocket as a server, bind to port 80 and configure to listen. I accept with a TCPSocket instance pointer and do my read/writes if accept is successful. If a network connection loss is detected ie connection status is no longer NSAPI_STATUS_GLOBAL_UP, both sockets are deleted and the process starts all over.
This works fine when I never actually connect to the socket. However, if I do connect to the socket, the socket is unable to bind when all of the TCPSockets instances are recreated.
Thanks in advance for any help.
#include “WebGui.h”
#include “Variables.h”
#include <stdio.h>
#include <string.h>
#include “slre.h”
EthernetInterface eth;
TCPSocket *client_sock;
TCPSocket *socket;
SocketAddress server_addr;
SocketAddress client_addr;
nsapi_version_t VersionType = NSAPI_IPv4;
int retval;
char sendBuffer[8500];
char receiveBuffer[5000];
char headerBuffer[100];
char XMLBuffer[2000];
#define disconnectCountout 5
int disconnectCounter = 0;
SocketAddress ip;
SocketAddress mask;
SocketAddress gateway;
void webMain()
printf(“Program Start\n”);
struct slre setTempRegex,minAlarmRegex, maxAlarmRegex;
struct cap captures[1 + 1];
if(!slre_compile(&setTempRegex, "setSetTemp=(\d*\.*\d*)&"))
printf("Invalid SLRE Expression: %s\n",setTempRegex.err_str);
if(!slre_compile(&minAlarmRegex, "setMinTemp=(\d*\.*\d*)&"))
printf("Invalid SLRE Expression: %s\n",minAlarmRegex.err_str);
if(!slre_compile(&maxAlarmRegex, "setMaxTemp=(\d*\.*\d*)&"))
printf("Invalid SLRE Expression: %s\n",maxAlarmRegex.err_str);
while(true)
//If web gui enabled
if(dhcpStatic != 0)
eth.set_as_default();
//If Static set
if(dhcpStatic == 2)
printf("Setting Static\n");
eth.set_dhcp(false);
char tempBuffer[15];
sprintf(tempBuffer,"%d.%d.%d.%d",IPAddress[0],IPAddress[1],IPAddress[2],IPAddress[3]);
ip = tempBuffer;
sprintf(tempBuffer,"%d.%d.%d.%d",Subnet[0],Subnet[1],Subnet[2],Subnet[3]);
mask = tempBuffer;
sprintf(tempBuffer,"%d.%d.%d.%d",Gateway[0],Gateway[1],Gateway[2],Gateway[3]);
gateway = tempBuffer;
retval = eth.set_network(ip,mask,gateway);
changeNetworkStatus = false;
//If DHCP set
else if(dhcpStatic == 1)
printf("Setting DHCP\n");
retval = eth.set_dhcp(true);
if(NSAPI_ERROR_OK != retval)
printf("Cannot configure the network: %d\n",retval);
changeNetworkStatus = true;
else
printf("Configuration Set: Returned %d\n",retval);
retval = eth.connect();
if (NSAPI_ERROR_OK != retval)
eth.disconnect();
printf("Unable to create ethernet interface: %d\n",retval);
if(dhcpStatic == 1)
networkStatus = 1;
else
networkStatus = 2;
else
networkStatus = 0;
if(dhcpStatic == 1)
eth.get_ip_address(&ip);
eth.get_netmask(&mask);
eth.get_gateway(&gateway);
memcpy(dhcpIPAddress,ip.get_ip_bytes(),4);
memcpy(dhcpSubnet,mask.get_ip_bytes(),4);
memcpy(dhcpGateway,gateway.get_ip_bytes(),4);
printf("Ethernet Connected: Returned %d\n",retval);
socket = new TCPSocket;
socket->set_timeout(1000);
/* Open the server on ethernet stack */
retval = socket->open(ð);
printf("Unable to open socket: Returned %d\n",retval);
else
printf("Socket Opened\n");
/* Bind the HTTP port (TCP 80) to the server */
retval = socket->bind(80);
printf("Unable to bind: Returned %d\n",retval);
else
printf("Socket Bound\n");
/* Can handle x simultaneous connections */
retval = socket->listen(1);
printf("Unable to listen: Returned %d\n",retval);
else
printf("Socket Listening\n\n");
client_sock = new TCPSocket;
while(true)
printf("Network Status %d\n",eth.get_connection_status());
if(eth.get_connection_status() != NSAPI_STATUS_GLOBAL_UP)
disconnectCounter++;
if(disconnectCounter >= disconnectCountout)
socket->close();
delete socket;
eth.disconnect();
delete client_sock;
if(dhcpStatic == 1)
dhcpIPAddress[0] = 0;
dhcpIPAddress[1] = 0;
dhcpIPAddress[2] = 0;
dhcpIPAddress[3] = 0;
dhcpSubnet[0] = 0;
dhcpSubnet[1] = 0;
dhcpSubnet[2] = 0;
dhcpSubnet[3] = 0;
dhcpGateway[0] = 0;
dhcpGateway[1] = 0;
dhcpGateway[2] = 0;
dhcpGateway[3] = 0;
networkStatus = 1;
break;
else
networkStatus = 2;
break;
client_sock = socket->accept(&retval);
printf("Unable to accept: Returned %d\n",retval);
else
//Read HTTP Request
client_sock->recv(receiveBuffer, 5000);
if (strstr(receiveBuffer,"ajax_switch"))
memset(sendBuffer,'\0',5000);
if (strstr(receiveBuffer,"resetTemps=1") != NULL)
resetRecordTemps = true;
printf("Received Record Reset\n");
if(slre_match(&setTempRegex, receiveBuffer, 5000, captures))
char intermediateBuffer[captures[1].len + 1];
for (int i = 0; i < captures[1].len; i++)
intermediateBuffer[i] = *(captures[1].ptr + i);
intermediateBuffer[captures[1].len] = '\0';
setTemp = atof(intermediateBuffer);
Eeprom_Write_Float(addr,ee_setTemp,setTemp);
if(slre_match(&minAlarmRegex, receiveBuffer, 5000, captures))
minAlarmTemp = atof(intermediateBuffer);
if(slre_match(&maxAlarmRegex, receiveBuffer, 5000, captures))
maxAlarmTemp = atof(intermediateBuffer);
strcpy(sendBuffer, createXMLHeader());
strcat(sendBuffer, createXML());
client_sock->send(sendBuffer, strlen(sendBuffer));
else
strcpy(sendBuffer, createStandardHeader());
strcat(sendBuffer, htmlString);
memset(receiveBuffer,'\0',5000);
client_sock->close();
