I am a new on mbed OS.
I am working on SPI for mbed-os 6.15 on H743ZI2.
I am using the SPI for encoder as5048a with library Saxion-Lectoraat-MT https://os.mbed.com/teams/Saxion-Lectoraat-MT/code/AS5048/.
I do get values from my SPI pin, but the value is not correct. It does not show the expected value for encoder, the value is more like randomly jump.
If someone familiar with stmH7, please help me.
My code:
#include “mbed.h”
#include <as5048spi.h>
// The sensors connection are attached to pins 5-8
As5048Spi sensor(PB_5, PB_4,PB_3, PA_4, 1);
static BufferedSerial serial_port(TARGET_TX_PIN, TARGET_RX_PIN, 9600);
FileHandle mbed::mbed_override_console(int fd)
return &serial_port;
while(1) {
const int angles = sensor.read_angle();
int angle = angles[0];
// The read angle returns the value returned over the SPI bus, including parity bit
printf("Read result: %x\r\n", angle);
if( As5048Spi::parity_check(angle) )
// Convert range from 0 to 2^14-1 to 0 - 360 degrees
int degrees = As5048Spi::degrees(angle)/100;
printf("Parity check succesfull.\r\n");
printf("Angle: %i degrees\r\n", degrees );
else
printf("Parity check failed.\r\n");
wait_ms(500);
