Hi
Has anyone got code and libraries for a sparkfun weather meter kit which will connect to the Waether shield are these shields compatible with Mbed nucleo boards or only Ardiuno , I need assistance urgently please .
Hi
you will probably not found a plug-and-play solution for this, but can try compose it like a puzzle.
SparkFun Weather Shield - DEV-13956 - SparkFun Electronics include
5 min with Search | Mbed, same time what you spent of creating two topics for same thing.
About hardware connection, hard to say. Arduino Uno is working with 5V logic, so the shield is prepared for 5V logic, but ARM architecture is usually 3.3V logic.
Thanks Jan
I will have a look sorry for the questions as i am new to this .
Hi Jan
I only find the below code for the weather station that I have , will it work with MBED6 ?
Hello again,
great, you found something.
Line 29 of WheaterMeters.h
// from this
class WeatherMeters : public Base {
// to this because I do not know where the base class can be and I don't see any relation with it
class WeatherMeters{
Lines 43-45 of WheaterMeters.cpp
// from this
int01.fall(this, &WeatherMeters::int_anemometer);
int02.fall(this, &WeatherMeters::int_raingauge);
ticker01.attach(this, &WeatherMeters::int_timer, 0.25);
// to this
int01.fall(callback(this,&WeatherMeters::int_anemometer));
int02.fall(callback(this,&WeatherMeters::int_raingauge));
ticker01.attach(callback(this,&WeatherMeters::int_timer), 250ms);
However this library is only for Anemometer, Wind vane, Rain gauge. For rest sensors you will need another libraries.
Thanks i will just add the pin numbers and hopefully it will work
Hi
So do i need to add pins to the code as i dont see any pins allocated and i see no printf function to display the values .
Thanking You
Please be so kind, scroll up and look my last post.
BTW it is not Mbed Studio 6. Mbed Studio is 1.4.3 and MbedOS is 6+ (6.15.1 is latest)
Hi there,
try change from Release profile to Debug profile.
Also take a look to windows Output and Problems - View->Output / View->Problems
Good day also for you,
nope that is not same errors. About those errors I already told you two times above, so be so kind and change the content of the library according to instructions
Hi Sir
It has been changed please see below , I have attached the code and library .
Link to library ;
https://os.mbed.com/users/okini3939/code/WeatherMeters/
main.cpp
Weathermeters.h :
(Attachment main.cpp is missing)
(Attachment WeatherMeters.h is missing)
Hi there,
You still have a chaos in your project I think.
According to first picture you have content of WeatherMeters.cpp inside of main.cpp
