Hello Liv,
I’m glad you made it work.
why the clocking needs to change for USB to function?
I think it’s because USB requires a very accurate clock to work reliably. An RC (resistor-capacitor) oscillator (like the internal one) is usually not accurate enough for USB. That’s why we better use the external crystal oscillator available on the Blackpill board, which is more precise.
Unless I am mistaken, though, the toolchain directories don’t seem to differ from TARGET_STM32F411xE. I was able to get past that by deleting TOOLCHAIN* from the custom target directory and adding “extra_labels_add”: [ “STM32F411xE” ] to custom_targets_.json in my project. Any downside to that?
You are right, Liv. The toolchain directories don’t differ from the TARGET_STM32F411xE. Buf the cmsis_nvic.h file should because the Blackpill is equipped with 256kB of flash memory as opposed to 512kB of the NUCLEO_F411RE. And to have a modified cmsis_nvic.h for the Blackpill the TOOLCHAIN folders have to be copied too. However, after checking the cmsis_nvic.h file it seems I forget to modify it (as below) so your remark was very useful. Thank you!
cmsis_nvic.h:
* SPDX-License-Identifier: BSD-3-Clause
* @attention
* <h2><center>© Copyright (c) 2016-2020 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
#ifndef MBED_CMSIS_NVIC_H
#define MBED_CMSIS_NVIC_H
#if !defined(MBED_ROM_START)
#define MBED_ROM_START 0x8000000
#endif
#if !defined(MBED_ROM_SIZE)
#define MBED_ROM_SIZE 0x40000 // 256 KB
#endif
#if !defined(MBED_RAM_START)
#define MBED_RAM_START 0x20000000
#endif
#if !defined(MBED_RAM_SIZE)
#define MBED_RAM_SIZE 0x20000 // 128 KB
#endif
#define NVIC_NUM_VECTORS 102
#define NVIC_RAM_VECTOR_ADDRESS MBED_RAM_START
#endif
Actually, there is a better solution. Add an “extra_labels_add”: [ “STM32F411xE” ] , as you did in the mbed_app.json, and “MBED_ROM_SIZE=0x40000” macro to the custom_targets.json file rather than copying the 'cmsis_nvic.h file and the TOOLCHAIN folders to the Blackpill custom target.
custom_targets.json:
"BLACKPILL": {
"inherits": [
"MCU_STM32F4"
"extra_labels_add": [
"STM32F411xE"
"macros_add": [
"STM32F411xE",
"MBED_ROM_SIZE=0x40000"
"config": {
"clock_source_usb": {
"help": "As 48 Mhz clock is configured for USB, SYSCLK has to be reduced from 100 to 60 MHz (set 0 for the max SYSCLK value)",
"value": "0",
"macro_name": "CLOCK_SOURCE_USB"
"overrides": {
"clock_source": "USE_PLL_HSE_XTAL",
"lse_available": 1
"device_has_add": [
"USBDEVICE"
"bootloader_supported": true,
"detect_code": [
"0740"
"device_name": "MCU_STM32F411CE"
And that is how I modified the Blackpill custom target.
