STM32F767ZI client socket hanging on connect
I am using an Nucleo STM32F767ZI with MBED OS 6.9.0, and I am running into issues with TCPSocket::connect() reporting -3004 (NSAPI_ERROR_NO_CONNECTION) error which is “not connected to a network.” This is despite the fact that “network.connect()” and “client.open(&network)” all report no error. (see code below).
I am checking if errors occur at each stage of the process which are all reporting that there are no issues. If I run the ST as a server (i.e. bind, accept, etc… are all working as expected), I can use my computer to send/recv information from the ST without issue. I only run into problems when trying to run the ST as a client.
When the code gets to “client.connect(server_address)” it hangs for a few seconds and reports the error.
    printf("Ethernet client example\n");
    nsapi_error_t conn_error = network.connect();
    print_tcp_error(conn_error);
    SocketAddress server_address("192.168.12.218", 1234);
    TCPSocket client;
    conn_error = client.open(&network);
    conn_error = client.connect(server_address);
    if (conn_error == 0)
        printf("Connection Open!\n");
    else
        return -1;
I am using PlatformIO, but I also tried MBED Studio with MBED OS 6.17.0 and the behavior is the same. Am I doing anything wrong, or is there possibly a bug I don’t know about? Any insight would be much appreciated.
usuall is good to start with official example of the API TCPSocket - API references and tutorials | Mbed OS 6 Documentation
I tried your code without significant changes and it is working as expected. Here is my setup
  • Nucleo-F767ZI
  • KeilStudioCloud
  • MbedOS 6.17
  • PC TCPserver app - Network Tool Connection (from MS store)
  • PC server IP address assigned by router
#include "EthernetInterface.h"
// Network interface
EthernetInterface network;
// Socket demo
    // Bring up the ethernet interface
    printf("Ethernet socket example\n");
    //print_tcp_error(conn_error);
    SocketAddress server_address("10.0.1.29", 8080);
    TCPSocket client;
    if (conn_error == NSAPI_ERROR_OK) printf("Connection Open!\n");
    // Close the socket to return its memory and bring down the network interface
    client.close();
    // Bring down the ethernet interface
    network.disconnect();
    printf("Done\n");
PC log from the app:
6/1/2023 9:11:16 PM  New connection from 10.0.1.34:55077
6/1/2023 9:11:16 PM  Remote connection disconnected. (10.0.1.34:55077)
I believe the issue will be on PC side, especially IP address settings.
Thank you for taking the time to run a test. Your recommendation to look at the PC side was the trick. It was a firewall setting preventing inbound connections.
