Hi, I have a strange problem. I have a class called “Manager” which implements all the logic of my application.
If I do something like this, all seems to work fine:
However, if I allocate my object at runtime, it only works randomly: often when trying to do a printf on a serial port it crashes (I found out that it goes to the infinite loop in startup.S).
Yes I used GDB. It goes to the Infinite_Loop in startupstm32xxx.S, the comment written near this loop states:
/* This is the code that gets called when the processor receives an
unexpected interrupt. This simply enters an infinite loop, preserving
Sorry for the late reply. gdb should allow you to break whenever it hits that function right? What’s the content of the stack & registers there?
If the code is not too confidential (and the schematics are easy enough for me to reproduce) I’d love to take a look at it. If you want, you can drop me a line at jan.jongboom@arm.com.
