Support EAP-TLS
I have a requirements from a customer to support 802.1X supplicant over wired LAN.
My system based on FREERTOS v10 + LWIP 2.1.2
Pls advise.
Kind Regards,
Leon.
Hi @leons
Mbed TLS is a TLS stack, and doesn’t support EAP-TLS.
However, you can implement the EAP protocol on top of Mbed TLS, and use the key export feature to export the key material for EAP-TLS.
Note that the key export feature is available on the feature branch, and not on any LTS branch.
You can look at the ssl_client2 example on how the key is derived for EAP-TLS.
Mbed TLS Support
Hi Ron,
Thank you for the info.
Best Regards,
Leon.
HI Leon,
You can also look at this article for explamation on the tls_prf feature.
Hi Ron,
I want to figure out some things,
The 802.1x is Port-Based Network Authentication, running on layer 2. ( there is no port, no IP).
First of all we have to setup EAPOL . (Start, request, response…).
If I understand correctly, if authenticator sends EAP-TLS start message, the supplicant have to start the SSL session (hello, certificates…) right?
I see mdebTls session (client ssl example), requires socket connection ( tcp layer) .
What I missing?
Kind Regards,
Leon.
Hi Leon,
Mbed TLS has the function mbedtls_ssl_set_bio() where you need to set the relevant bio callbacks of your connection. It doesn’t need to be tcp layer. Mbed TLS is release with a BSD type socket example, however, you can change it to your transport type callback.
You can look as reference how EAP-TLS is implemented in Mbed-OS over Mbed TLS here
Hi Ron,
I can’t find the function: ```
mbedtls_ssl_conf_export_keys_ext_cb
as described in: https://tls.mbed.org/kb/how-to/tls_prf
My package: mbedtls-2.16.3
Kind Regards,
Leon.
Hi Leon,
As mentioned in this comment, this feature is available only in the feature branch (development branch), and not available yet in an officially released version.
