Hello, amazing people!
I have a small question about TL062CD
Can the VCC of the TL062CD op-amp be powered by plus or minus 5v? Will it be small? It seems not to be said in on datasheet. This is the datasheet about it:https://www.utmel.com/components/tl062cd-op-amp-datasheet-schematic-typical-application?id=551
If I lost something detailed.
Good listening!
Hello Guo,
According to this TL06xx datasheet +/-5V is the minimum recommended power supply voltage:
The short answer in case you are really new to this is that you need both plus and minus voltages and 0v (ground).
Both + and - voltages need to be the same magnitude in the range 5 - 15V, it won’t work well if you have +5V and -10V (for example). There is a typical circuit on p16 of the datasheet linked by Mr Hudak:
Hope it helps.
OK, Thank you!
Hi, Chris!
Thank you, I think I got it!
