Timer resolution in Mbed OS
I noticed that the method to count the time duration “elapsed_time().count()” has the resolution of 1us and delay around 10us. Is there a way to have a more precise timer/counter?
In addition, how or where can I access the lower level library?
Thank you in advance!
Generally, to get better precision than microseconds, you will need to use a hardware timer on your microcontroller. What model of MCU are you using? I can try to point you to some resources.
Hi Jamie,
It’s LPC1768. Not sure if this is the correct link
Any example code is appreciated.
Oh now that’s a chip I have some experience with! Here’s a page that looks like a decent guide on how to configure TIM0 and TIM1: LPC1768: Timers - Tutorials . You can set them to run at a higher frequency than 1us, e.g. the processor’s core clock frequency (no prescaler).
Once you have configured a timer (say, TIM0), you can then use LPC_TIM0->TC to access the current count.
By default, Mbed OS uses TIM3 internally to implement the us ticker, leaving the other three timers available for your use.
Thanks for your tutorial link and swifty! I think that’s exactly what I’m looking for.
Since we talked about the hardware Timer, can you help me further if you know there’s any risk when I use external interrupts to start&stop the timer counting?
Risk? Of what?
A silly question from me: does the hardware timer stop if interrupt occurs?
No, that shouldn’t happen unless you specifically set the LPC_TIM0->MCR register to reset the timer when it hits one of the match registers.
Understood. Thanks for your great help.
