Hi there,
I’ve posted on GitHub to no avail, so I thought I’d try my luck here.
I am using the debug() function (from mbed_debug.h) to print a bunch of info/error messages when using the debug build profile. Under specific circumstances I instantiate a UARTSerial object in the following way, where the TX/RX pins are the same as used for the mbed_debug UART:
UARTSerial *_serial;
_serial = new UARTSerial(TX, RX, BAUD);
The creation of this UARTSerial object breaks the debug() output. My question is a simple one; is there an explicit function call I can make to re-instantiate the UART used by mbed_debug after deleting my _serial object?
If not, I am using the UARTSerial object with an ATCmdParser:
_parser = new ATCmdParser(_serial);
Is there a way to access the object used by mbed_debug in a way that’s compatible with the ATCmdParser? This would save having to instantiate a new UARTSerial object in the first place. This would be the preferred solution.
Adam
