UART Rx interrupt while using BufferedSerial
I’m using a BufferedSerial interface to comunicate with a modem via AT commands, the response time of the modem is highly variable (from ms to minutes depending on the command). Right now to wait for a response I’m using ThisThread::sleep_for() with a time delay manually adjusted. This approach has worked more or less so far but it’s not consistent nor optimal.
Another way I thought this could be solved is with the use of flags, I can wait for a flag to be set from the interrupt generated by the serial interface using ThisThread::flags_wait_any().
The problem I have is that I can’t find a way to generate an IRQ using BufferedSerial…
Best regards,
Lalo
Hello Lalo,
When using the BufferedSerial you can attach an ISR to the sigio. For example as shown here.
Best regards, Zoltan
Hello Zoltan,
Thank you for your help, it’s working!
