Hello. It used to be that ThisThread::sleep_for needed an annotated integral type. However a new project I’ve created in the same way as another older (as in months older, not years) project gets a compilation error when I pass e.g. 100ms.
Has anyone encountered this? I’d like to trace down the compiler problem I am having before it starts causing issues.
There are some ways to handle wait functions with 6.7, normally they use literals from the chrono library for ms or s, (us doesn’t work!): ThisThread::sleep_for(2s) ThisThread::sleep_for(2ms) thread_sleep_for(5ms) this should used for bare metal I think
for pass a variable you need do this: int delay = 500; ThisThread::sleep_for(chrono::milliseconds(delay));
following should also work wait_us(delay); wait_ms is deprecated
So many old libraries doesn’t work anymore, what a shame.
I’m aware of how the constants work and quite like it. My issue is that when I made projects a few months ago, I needed to use chrono typed literals. Now I am getting an error if I add the ms suffix as in the title.
I’m unable to tell how my toolchain changed. I’m using the latest 10.x gcc release instead of the 9.x release.
