Following is the code I’m trying to use:
* @file BufferedSoftSerial.cpp
* @brief Software Buffer - Extends mbed Serial functionallity adding irq driven TX and RX
* @author sam grove
* @version 1.0
* @see
* Copyright (c) 2013
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
//K64F
#include<string>
Serial pc(PA_2, PA_3); // tx, rx
#include "BufferedSoftSerial.h"
#include <stdarg.h>
BufferedSoftSerial::BufferedSoftSerial(PinName tx, PinName rx, const char* name)
: SoftSerial(tx, rx, name)
SoftSerial::attach(this, &BufferedSoftSerial::rxIrq, SoftSerial::RxIrq);
return;
int BufferedSoftSerial::readable(void)
return _rxbuf.available(); // note: look if things are in the buffer
int BufferedSoftSerial::writeable(void)
return 1; // buffer allows overwriting by design, always true
int BufferedSoftSerial::getc(void)
return _rxbuf;
int BufferedSoftSerial::putc(int c)
_txbuf = (char)c;
BufferedSoftSerial::prime();
return c;
int BufferedSoftSerial::puts(const char *s)
const char* ptr = s;
while(*(ptr) != 0) {
_txbuf = *(ptr++);
_txbuf = '\n'; // done per puts definition
return (ptr - s) + 1;
int BufferedSoftSerial::printf(const char* format, ...)
char buf[256] = {0};
int r = 0;
va_list arg;
va_start(arg, format);
r = vsprintf(buf, format, arg);
// this may not hit the heap but should alert the user anyways
if(r > sizeof(buf)) {
error("%s %d buffer overwrite!\n", __FILE__, __LINE__);
va_end(arg);
r = BufferedSoftSerial::write(buf, r);
return r;
ssize_t BufferedSoftSerial::write(const void *s, size_t length)
const char* ptr = (const char*)s;
const char* end = ptr + length;
while (ptr != end) {
_txbuf = *(ptr++);
return ptr - (const char*)s;
void BufferedSoftSerial::rxIrq(void)
// read from the peripheral and make sure something is available
if(SoftSerial::readable()) {
_rxbuf = _getc(); // if so load them into a buffer
return;
void BufferedSoftSerial::txIrq(void)
// see if there is room in the hardware fifo and if something is in the software fifo
while(SoftSerial::writeable()) {
if(_txbuf.available()) {
_putc((int)_txbuf.get());
} else {
// disable the TX interrupt when there is nothing left to send
SoftSerial::attach(NULL, SoftSerial::TxIrq);
break;
return;
void BufferedSoftSerial::prime(void)
// if already busy then the irq will pick this up
if(SoftSerial::writeable()) {
SoftSerial::attach(NULL, SoftSerial::TxIrq); // make sure not to cause contention in the irq
BufferedSoftSerial::txIrq(); // only write to hardware in one place
SoftSerial::attach(this, &BufferedSoftSerial::txIrq, SoftSerial::TxIrq);
return;
BufferedSoftSerial device(PB_14, PB_15); // tx, rx
device.baud(9600);
while(1) {
if(pc.readable()) {
device.putc(pc.getc());
if(device.readable()) {
pc.putc(device.getc());
But, I’m unable to get it work. Can someone please show me a working example.
