Hellow. I am learning cpp and mbed recently. please help to write 6 uint numbers from usb cdc. I read the documentation USBCDC - APIs | Mbed OS 5 Documentation but found in it just an example of sending. I apologize for not showing the code. I don’t even know where to start
Hello Nikita,
You can try the following:
#include "USBCDC.h"
USBCDC cdc;
unsigned int data[6] = { }; // data array
uint8_t* p_data = (uint8_t*)data; // write pointer
uint32_t size_read; // the number of bytes actually received
int main(void)
while (1) {
cdc.receive_nb(p_data, 1, &size_read); // write received byte to data array
p_data += size_read; // advance the write pointer by the number of bytes actually received
if (p_data == (uint8_t*)data + sizeof(data)) { // when array is full
printf("Data received:\r\n");
for (uint8_t i = 0; i < 6; i++) {
printf("data[%d] = %d\r\n", i, data[i]);
p_data = (uint8_t*)data; // reset the write pointer
thread_sleep_for(10);
Hello Hudakz,
I need to receive a JSON string using USB CDC without knowing the length of the JSON string. The data has de following structure:
0x01 | two bytes for JSON string len | JSON string
In the example above you use receive_nb() but you have a fixed length for the data received. How can I receive the JSON string without previously knowing its length?
Hello Yan,
You can get started for example with the following code:
#include "USBCDC.h"
#define MAX_LEN 512 // packet max length
USBCDC cdc;
uint8_t packet_data[MAX_LEN] = { 0 }; // allocate memory for a packet and clear content
uint8_t* receive_pointer; // set receive pointer
uint16_t packet_len;
uint16_t json_len; // length of the json string received
uint32_t read_len; // number of bytes actually received
bool receiving_packet; // status variable
bool receiving_json; // status variable
void reset_vars()
memset(packet_data, 0, MAX_LEN); // clear packet data
receive_pointer = packet_data; // reset receive pointer
packet_len = 0;
json_len = 0;
receiving_packet = false;
receiving_json = false;
void parse_json()
char* json_string = (char*) &packet_data[3];
printf("JSON string received:\r\n");
printf("%s\r\n", json_string);
// ... your json parser
void set_json_len()
json_len = (uint16_t) packet_data[1]; // set json string length
receiving_json = true;
void get_json_data()
if (packet_len > (1 + 2 + json_len)) {
printf("Error: Garbage packet received\r\n");
reset_vars();
return; // get new packet
if (packet_len == (1 + 2 + json_len)) {
printf("Packet is complete\r\n");
parse_json(); // Parse the received json string
reset_vars(); // Reset variables
int main(void)
reset_vars();
while (1) {
cdc.receive_nb(receive_pointer, 64, &read_len); // write received bytes (if any) to packet_data and update read_len
if (read_len > 0) {
if (receiving_packet) {
receive_pointer += read_len; // advance the receive pointer by the number of bytes actually received
packet_len += read_len; // number of packet bytes received so far
if (receiving_json) {
get_json_data();
else if (packet_len >= (1 + 2)) {
// json string legth data available
set_json_len();
else {
// check if the first byte is equal to 0x01 -> start of a new packet
if (packet_data[0] == 0x01) {
// Start of a new packet
receiving_packet = true;
set_json_len();
get_json_data();
thread_sleep_for(10); // wait for new bytes
The code above compiles but has not been tested.
Best regards, Zoltan
Hello Zoltan!
The code is working! I just had to change the following function to consider the two bytes of the size field:
void set_json_len()
json_len = packet_data[1] << 8 | packet_data[2]; // set json string length
I really appreciate your help. Thank you very much!
Hello Yan,
I’m glad you made it work ![]()
Yes, you are right. I made a mistake in the set_json_len()
I should make a cast as below:
void set_json_len()
//json_len = (uint16_t) packet_data[1]; // set json string length
json_len = *((uint16_t*) &packet_data[1]); // set json string length
But your code solved it.
