Hi guys,
I am trying to implement an InterruptIn as a part of a PwmIn header file. When the .rise & .fall conditions occur I would like to call a function (also held within the header file) however, I am not sure of the correct methodology/syntax in OS 6 to achieve this. The lines _pwm.rise(&PwmIn::rise) and _pwm.fall(&PwmIn::rise) generate the following error:
No viable conversion from 'void (PwmIn::*)()' to 'Callback<void ()>'clang(typecheck_nonviable_condition)
my headerfile…
#ifndef PWMIN_H
#define PWMIN_H
class PwmIn{
public:
//create PWM input object
PwmIn(PinName pwm);
//returns the period of the signal in seconds
float readPeriod();
//returns the ducty cycle of the signal as a decimal percentage
float readDutyCycle();
private:
InterruptIn _pwm;
Timer _timer;
void rise();
void fall();
float _period;
float _pulseWidth;
#endif
Implementation…
#include "PwmIn.h"
#include <chrono>
PwmIn::PwmIn(PinName pwm) : _pwm(pwm){
_pwm.rise(&PwmIn::rise);
_pwm.fall(&PwmIn::fall);
_period = 0.0;
_pulseWidth = 0.0;
_timer.start();
float PwmIn::readPeriod() {
return _period;
float PwmIn::readDutyCycle() {
return _pulseWidth / _period;
void PwmIn::rise() {
_period = chrono::duration_cast<std::chrono::seconds>(_timer.elapsed_time()).count();
_timer.reset();
void PwmIn::fall() {
_pulseWidth = chrono::duration_cast<std::chrono::seconds>(_timer.elapsed_time()).count();
Any help regarding how to call these functions correctly would be greatly appreciated!!
Thanks in advance,
Andy
