I have 3 certificates:
Root cert
Intermediate cert (signed by Root)
Device cert (signed by Intermediate)
I’m trying to figure out if they form a valid chain:
what follows is pseudocode, but should be understandable.
/* Taken from mbedtls/programs/x509/cert_app.c */ static int my_verify( void *data, mbedtls_x509_crt *crt, int depth, uint32_t *flags ) { char buf[1024]; ((void) data); log_error( "\nVerify requested for (Depth %d):\n", depth ); mbedtls_x509_crt_info( buf, sizeof( buf ) - 1, "", crt ); log_error( "%s", buf ); if ( ( *flags ) == 0 ) log_error( " This certificate has no flags\n" ); else { mbedtls_x509_crt_verify_info( buf, sizeof( buf ), " ! ", *flags ); log_error( "%s\n", buf ); } return( 0 ); } /* Start of chain */ mbedtls_x509_crt_parse(devcrt, devcrt_char_array, length_of_devcrt_char_array); /* Add the intermediate to the chain */ mbedtls_x509_crt_parse(devcrt, intermediate_crt_char_array, length_of_intermediate_crt_char_array); /* Add the root to the chain */ mbedtls_x509_crt_parse(devcrt, root_crt_char_array, length_of_root_crt_char_array); /* Parse the root cert */ mbedtls_x509_crt_parse(rootcrt, root_crt_char_array, length_of_root_crt_char_array); /* Verify the chain against the root */ mbedtls_x509_crt_verify(&devcert, &rootcert, NULL, NULL, &flags, my_verify, NULL)
Verify fails with error:
[my_verify:88] ERROR: Verify requested for (Depth 0):
[my_verify:90] ERROR:cert. version : 3
serial number : 01
issuer name : REDACTED , CN= Intermediate
subject name : REDACTED , CN=Device
issued on : 2019-01-28 09:14:48
expires on : 2040-01-01 09:14:48
signed using : ECDSA with SHA256
EC key size : 256 bits
basic constraints : CA=false
subject alt name : m:m:m[my_verify:97] ERROR: ! The certificate is not correctly signed by the trusted CA
What is strange that if I make a chain with only the intermediate cert, than i can verify that cert with the root cert and if I make a chain with only the dev cert, then I can verify the dev cert with the intermediate cert, so the certs look fine. But somehow making a chain of all 3 certs fails when I verify with the root cert.
Can someone explain what might be going on? Should I add the intermediate certificate to the trusted chain instead of only the root cert?
