I am very new to cryptography and am working on an application which signs a file and at an embedded device end, i have to verify that file, but am having hard time doing it using mbedTLS. Below is the code:
int main(int argc, char **argv)
int ret = 0;
char privateKey[] = "-----BEGIN RSA PRIVATE KEY-----\n"
"MIIEowIBAAKCAQEAjFFQtxIIZ2nn/lfoub9EFLHWORT21T9+jY1YIxzBlsh3EjLZ\n"
"s7SGvbUd4LlIjW4s/BhI0rTxXpgVcROyHbk1dVmWkuBBZxTHT2rtX07kas38ZeJk\n"
"2FaKL9Y4+moc6Q+dwwBU/WChDrihIC2F0FjZEvzlAo06XB+kCkoAS7v0h76w+Zhq\n"
"Z1Ww6mgmAg8+l2vtMuuyvCbQLJuKtV75l8p3Nvf4AI08MdMm3LETF4uVErJLu3dG\n"
"LvXzn56uNSE+4RLYnb75loUosyEdjKAdZzJ54603AO1OohvoXuiY6kavV/CQPWVx\n"
"WKntnkPg6/G6R1w/8bSP/UIYjk9dvVpZOHa6fQIDAQABAoIBAFhnWt0cZWMSHHHo\n"
"XN26HWCUco1gIetUp5zzMlZc5bLj9fDnTLWlxUZ8d6h/07AXfAwQGMF38qJQWyH0\n"
"8ME9UOrwWKeM1mfldXUZvxfPEqYfxSdDrZmHXGSrKRbMCA7mIdUbvnAskww9UnZ9\n"
"d9M+RvVpk7c510z3OlipKuqMLpHepJn1fI8pdh44gFDhcI6uYMNSIu+/cY5zQydQ\n"
"HCIgoWBxwW+pC1qpUa9MwsTEFTD8ttrYkVsp8C9Y2adyuxtEQekdmbjvmve0pI4y\n"
"Iz4rmAgp/FA5PigRD9jnLL+8drHf7k4COSdP6S83fEFFDIFpVLzamSz5xoGlKNha\n"
"vvRPfcECgYEA6RmFczmpuBwnxnNFMCVkle5/dnkxKq1LbGwr163LyHkS70kganje\n"
"/obsYGVENpYeQF8tzMh24/9uWSxGignIJKP2OFJARumWX230KGQ92jgvwEsN+UB3\n"
"ga/gbwMvnAbmnTQWDKhpfps1MFKkfCb9XWv4fYIILZALaoxF34aab9kCgYEAmhpR\n"
"GWYODHlkzSqC3vb23VbIIYPoric64SAGCWj0Z+45JQeQXTAtLvcabo+QzX+BW8DH\n"
"7d0euo2YOfNv3R3T1z7X5xVpzDP2RlE4/KK87wHYIVjMzi/8EgDwyqoPzmtlyIqm\n"
"+vsEhpPZYpXL/EdxwcKcYJrHUcf+BdUDBTOjHUUCgYBeUJI7dghi0xmQ5VEIUwjo\n"
"1VBDinPHVcjfvMDcipiaq8pqgUcZbYCkscjwk+jOwVzKJPiuFCpuxApNEGoWLjEK\n"
"CkF0tmsFhjvurtmMgkq4geVoQ7YKtPflxFjl8f8QfYZP8yQ8yOOuc3RI8hdVmJ0J\n"
"cMdhWPygGtlTqiAXeioAuQKBgDKsIKrHYis756eHKQ2EC9zwYlKS+3n4sGXCj/mc\n"
"J3HdZbEFcbUS2GivHGPqlWTdXn37QEK5CRey47F6mPgOjNAke/4ijm11ULACmUiJ\n"
"grLc2mLsvju2j56j7InXrebkbc2pugqha/WMvFishSzpmUBra9xgSNZdeuwUBTA6\n"
"sJI5AoGBAOci192K7xOzn3ltMTPLqE6TpDM40TwhTZ2X3+m2OjTZtKEcRYIVTiUa\n"
"x8Vv6r92afGFLNkcZ0gEe3VU5jHfgi0dVsQPeJWUqiqN1quHWk+3y0PAlAgw2wIL\n"
"WKx0uF/rHj16tRsOoJ2c99Q3wgtJC8gj9kJQH6vZoqxvF3YAF+mm\n"
"-----END RSA PRIVATE KEY-----\n";
char pubKey [] = "-----BEGIN PUBLIC KEY-----\n"
"MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAjFFQtxIIZ2nn/lfoub9E\n"
"FLHWORT21T9+jY1YIxzBlsh3EjLZs7SGvbUd4LlIjW4s/BhI0rTxXpgVcROyHbk1\n"
"dVmWkuBBZxTHT2rtX07kas38ZeJk2FaKL9Y4+moc6Q+dwwBU/WChDrihIC2F0FjZ\n"
"EvzlAo06XB+kCkoAS7v0h76w+ZhqZ1Ww6mgmAg8+l2vtMuuyvCbQLJuKtV75l8p3\n"
"Nvf4AI08MdMm3LETF4uVErJLu3dGLvXzn56uNSE+4RLYnb75loUosyEdjKAdZzJ5\n"
"4603AO1OohvoXuiY6kavV/CQPWVxWKntnkPg6/G6R1w/8bSP/UIYjk9dvVpZOHa6\n"
"fQIDAQAB\n"
"-----END PUBLIC KEY-----\n";
char testString[] = "Testing";
char eHash[]="MDUr0X1J7pZEzminqKaCnpV77tAU/w3gnTwVzip1Z0dG77Mb6z2tnFb1aYPMyp3za2+XONJJCDY4H+pqW0uqM8j5DrhHhHwCf0l4NXi3Wy7fBsUr57fywFmgRBEfZiMVejHuq4/ns5NpC9CYa99u/YQYwjgf69KjXUoctAH5P35KFx7MS3TZukGPo/T/Ew5BGa2oBJhy+ttP7tCMUxOHfByWt0+Agkg0Zt1/xO++T2kN8vHny7Zk6Vm2xjH5UM3we1XVBvmIaMGXptultHVF6aLUQKCVcKSa26CneDFnImg3Mclz1gfOSNmC+ZuHsFIWWzpromxFFvErI9dash7Hhg==";
mbedtls_pk_context pk;
mbedtls_pk_init( &pk );
ret = mbedtls_pk_parse_public_key( &pk, // key to be initialized (pk_context must be empty)
pubKey, sizeof(pubKey)); // path to filename to read the public key from
if( ret != 0 )
mbedtls_printf( " failed\n ! Could not read key from '%s'\n", pubKey );
mbedtls_printf( " ! mbedtls_pk_parse_public_keyfile returned %d\n\n", ret );
return -1;
// Set padding for an already initialized RSA context
mbedtls_rsa_set_padding( mbedtls_pk_rsa( pk ), // RSA context to be set
MBEDTLS_RSA_PKCS_V15, // Padding scheme (MBEDTLS_RSA_PKCS_V21 or MBEDTLS_RSA_PKCS_V15)
MBEDTLS_MD_SHA512 ); // MBEDTLS_RSA_PKCS_V21 hash identifier (ignored for PKCS_V15)
// Verify the RSA signature of the hash (includes padding if relevant)
ret = mbedtls_pk_verify( &pk, // PK context to use
MBEDTLS_MD_SHA512, // Hash algorithm used
eHash, // Hash of the message to verify signature for
sizeof(eHash), // hash length (0 -> use length associated with the Hash algorithm)
testString, // Signature to verify
sizeof(testString) ); // Signature length
if( ret != 0 )
mbedtls_printf( " failed\n ! mbedtls_pk_verify returned %d\n\n", ret );
return -1;
return 0;
I am getting “! mbedtls_pk_verify returned -17280” as output.
The eHash is a hash generated using 2048 bit RSA private key given by ‘privateKey’ on ‘testString’. Quick help is appreciated. Thanks
