Hello.
My configuration is:
- Development host: Xubuntu
- Mbed-cli: version 1.10.2 with python 2.7.17
- Compiler: gcc-arm-none-eabi version 9-2019-q4-major
- Debug server: xPack OpenOCD 0.10.0+dev (2019-07-17-11:25)
- Target: ST NUCLEO 466 RG
I have set up a test program mms2 and exported it to VSC with the command:
mbed export -i vscode_gcc_arm -m NUCLEO_466RG -t gcc_arm
I have then manually (!!!) edited tasks.json (incidentally, mbed exports version 0.1.0 which is deprecated: VSC complains saying “Task version 0.1.0 is deprecated. Please use 2.0.0”) to this:
// See https://go.microsoft.com/fwlink/?LinkId=733558
// for the documentation about the tasks.json format
"version": "0.1.0",
"name": "mbed",
"isShellCommand": true,
"showOutput": "always",
"problemMatcher": {
"owner": "cpp",
"fileLocation": ["relative", "${workspaceRoot}/mbed-os"],
"pattern": {
"regexp": "^(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
//"args": ["compile", "--profile=debug", "-t", "GCC_ARM", "-m", "YOUR_TARGET"],
"args": ["compile", "-j","8", "--profile=debug"],
"linux": {
"command": "mbed"
"osx": {
"command": "mbed"
"windows": {
"command": "mbed"
according to the instructions found here.
Following the same instructions I have then manually (!!!) edited tasks.json to this:
"version": "0.2.0",
"configurations": [
"name": "C++ Launch",
"type": "cppdbg",
"request": "launch",
"program": "${workspaceRoot}/BUILD/NUCLEO_F446RE/GCC_ARM-DEBUG/${workspaceRootFolderName}.elf",
"args": [],
"stopAtEntry": true,
"cwd": "${workspaceRoot}",
"environment": [],
"externalConsole": true,
"serverLaunchTimeout": 20000,
"filterStderr": true,
"filterStdout": false,
"serverStarted": "GDB\\ server\\ started",
"preLaunchTask": "mbed",
"setupCommands": [
{ "text": "-target-select remote localhost:3333", "description": "connect to target", "ignoreFailures": false},
{ "text": "-file-exec-and-symbols ${workspaceRoot}/BUILD/NUCLEO_F466RE/GCC_ARM-DEBUG/${workspaceRootFolderName}.elf", "description": "load file", "ignoreFailures": false},
{ "text": "-interpreter-exec console \"monitor endian little\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor reset\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor halt\"", "ignoreFailures": false },
{ "text": "-interpreter-exec console \"monitor arm semihosting enable\"", "ignoreFailures": false },
{ "text": "-target-download", "description": "flash target", "ignoreFailures": false }
"logging": {
"moduleLoad": true,
"trace": true,
"engineLogging": true,
"programOutput": true,
"exceptions": true
"linux": {
"MIMode": "gdb",
"debugServerArgs": "-f /opt/xPacks/openocd/latest/scripts/interface/stlink.cfg -c \"transport select hla_swd\" -f /opt/xPacks/openocd/latest/scripts/target/stm32f4x.cfg -c init -c \"reset init\"",
"MIDebuggerPath": "/opt/arm/latest/bin/arm-none-eabi-gdb",
"debugServerPath": "/opt/xPacks/openocd/latest/bin/openocd"
"osx": {
"MIMode": "gdb",
"MIDebuggerPath": "arm-none-eabi-gdb",
"debugServerPath": "pyocd-gdbserver"
"windows": {
"MIMode": "gdb",
"debugServerArgs": "-f \"C:\\opt\\OpenOCD\\latest\\scripts\\interface\\stlink.cfg\" -c \"transport select hla_swd\" -f \"C:\\opt\\OpenOCD\\latest\\scripts\\target\\stm32f4x.cfg\" -c init -c \"reset init\" ",
"MIDebuggerPath": "C:/opt/GNU-Tools-Arm-Embedded/latest/bin/arm-none-eabi-gdb.exe",
"debugServerPath": "C:/opt/openocd/latest/bin/openocd.exe",
"setupCommands": [
{ "text": "-environment-cd ${workspaceRoot}/BUILD/NUCLEO_F446RE/GCC_ARM-DEBUG/" },
{ "text": "-target-select remote localhost:3333", "description": "connect to target", "ignoreFailures": false },
{ "text": "-file-exec-and-symbols ${workspaceRootFolderName}.elf", "description": "load file", "ignoreFailures": false},
Now, when I click Start Debugging in VSC I get the following:
output
Building project mms2 (NUCLEO_F446RE, GCC_ARM)
Scan: mms2
Link: mms2
Elf2Bin: mms2
| Module | .text | .data | .bss |
| LedMan.o | 282(+0) | 0(+0) | 0(+0) |
| LedThread.o | 236(+0) | 0(+0) | 192(+0) |
| [fill] | 80(+0) | 0(+0) | 23(+0) |
| [lib]/c.a | 5072(+0) | 2108(+0) | 89(+0) |
| [lib]/gcc.a | 760(+0) | 0(+0) | 0(+0) |
| [lib]/misc | 180(+0) | 4(+0) | 28(+0) |
| main.o | 186(+0) | 0(+0) | 37(+0) |
| mbed-os/drivers | 68(+0) | 0(+0) | 0(+0) |
| mbed-os/hal | 1720(+0) | 4(+0) | 66(+0) |
| mbed-os/platform | 5042(+0) | 260(+0) | 348(+0) |
| mbed-os/rtos | 9542(+0) | 168(+0) | 6101(+0) |
| mbed-os/targets | 7392(+0) | 8(+0) | 556(+0) |
| Subtotals | 30560(+0) | 2552(+0) | 7440(+0) |
Total Static RAM memory (data + bss): 9992(+0) bytes
Total Flash memory (text + data): 33112(+0) bytes
Image: ./BUILD/NUCLEO_F446RE/GCC_ARM-DEBUG/mms2.bin
[mbed] Working path "/media/sf_Documents/mbed-cli/mms2" (program)
[mbed] Detected "NUCLEO_F446RE" connected to "/media/alberto/NODE_F446RE" and using com port "/dev/ttyACM0"
Debug Console
1: (427) LaunchOptions<LocalLaunchOptions xmlns='http://schemas.microsoft.com/vstudio/MDDDebuggerOptions/2014'
1: (474) LaunchOptions ExePath='/media/sf_Documents/mbed-cli/mms2/BUILD/NUCLEO_F446RE/GCC_ARM-DEBUG/mms2.elf'
1: (474) LaunchOptions WorkingDirectory='/media/sf_Documents/mbed-cli/mms2'
1: (474) LaunchOptions ExeArguments=''
1: (474) LaunchOptions MIMode='gdb'
1: (474) LaunchOptions MIDebuggerPath='/opt/arm/latest/bin/arm-none-eabi-gdb'
1: (474) LaunchOptions WaitDynamicLibLoad='false'
1: (475) LaunchOptions DebugServer='/opt/xPacks/openocd/latest/bin/openocd'
1: (475) LaunchOptions DebugServerArgs='-f /opt/xPacks/openocd/latest/scripts/interface/stlink.cfg -c "transport select hla_swd" -f /opt/xPacks/openocd/latest/scripts/target/stm32f4x.cfg -c init -c "reset init"'
1: (475) LaunchOptions ServerStarted='GDB\ server\ started'
1: (475) LaunchOptions FilterStderr='true'
1: (475) LaunchOptions ServerLaunchTimeout='20000'
1: (475) LaunchOptions ExternalConsole='true'
1: (476) LaunchOptions>
1: (476) LaunchOptions <SetupCommands>
1: (476) LaunchOptions <Command IgnoreFailures='false' Description='connect to target'>-target-select remote localhost:3333</Command>
1: (476) LaunchOptions <Command IgnoreFailures='false' Description='load file'>-file-exec-and-symbols /media/sf_Documents/mbed-cli/mms2/BUILD/NUCLEO_F466RE/GCC_ARM-DEBUG/mms2.elf</Command>
1: (476) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor endian little"</Command>
1: (476) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor reset"</Command>
1: (477) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor halt"</Command>
1: (477) LaunchOptions <Command IgnoreFailures='false' Description=''>-interpreter-exec console "monitor arm semihosting enable"</Command>
1: (477) LaunchOptions <Command IgnoreFailures='false' Description='flash target'>-target-download</Command>
1: (477) LaunchOptions </SetupCommands>
1: (477) LaunchOptions</LocalLaunchOptions>
1: (735) Starting: "/opt/xPacks/openocd/latest/bin/openocd" -f /opt/xPacks/openocd/latest/scripts/interface/stlink.cfg -c "transport select hla_swd" -f /opt/xPacks/openocd/latest/scripts/target/stm32f4x.cfg -c init -c "reset init"
1: (20850) <-logout
1: (20883) Send Event AD7MessageEvent
and I get the Error dialog below
Note that if I launch on a separate command line window the command
/opt/xPacks/openocd/latest/bin/openocd -f /opt/xPacks/openocd/latest/scripts/interface/stlink.cfg -c \"transport select hla_swd\" -f /opt/xPacks/openocd/latest/scripts/target/stm32f4x.cfg -c init -c \"reset init\"
the debugger comes up without any error.
Any clues on what I may be missing?
Thanks in advance
Alberto
