I have to press the reset button everytime I copy the ‘.bin’ file to the B-L475E-IOT01A1 board for the code to run. Is there a way to run the code without pressing the reset button?
Hi
What is your HW revision ?
Please find the details below:
Board - B-L475E-IOT01A2
Rev - MB1297 C-01
OK, you have an old one…
See User Manual: https://www.st.com/resource/en/user_manual/dm00347848-discovery-kit-for-iot-node-multichannel-communication-with-stm32l4-stmicroelectronics.pdf
in Appendix C Board revision history and limitations
You should get a D-01 version
Okay, Thank you for the information.
So, just wanted to check if there is no workaround to run the code without pressing reset button for revision C boards?
See in Appendix C:
a simple workaround is available
by soldering an external wire
between the SB2 and SB8.
