Hello!
I have mbed NXP LPC1768.
My program is:
There is a variable that keeps milliseconds which started with mbed.
In While loop I saved it every 4 milliseconds in a buffer.
at the same time, a thread writes this buffer variables to the sd card file.
-Every 4ms ( Must be a multiple of 4 ) I saved it into a buffer.
-When buffer size is up to 50 (and multiple of 50) flag is opened and Thread writing that 50 variables to the sd card file.
-When buffer size is reach 2500 program is over. OK
My problem is when I read variables:
1- First 1000 ms variables normal. (4-8-12-16-20-…-1000) …OK
2- After 1000 It is changing. (1000-1008-1016-1020-1028-1036-1040-1048-1056-1060-…)
It is like pattern (+4 , + 8, +8 ,+4 ,+8 ,+8 , +4…)
Do you have an idea for this reason? It Must be a multiple of 4 from start until end.
THANK YOU!
My code is :
#include “mbed.h”
#include <stdio.h>
#include “SDBlockDevice.h”
#include “FATFileSystem.h”
// Physical block device, can be any device that supports the BlockDevice API xx
SDBlockDevice blockDevice(p5, p6, p7, p10); // mosi, miso, sck, cs
// File system declaration
FATFileSystem fileSystem(“fs”); // fs is root of the SD Card Folder
using namespace std::chrono;
Timer t;
int timer_time;
int err;
FILE *f;
volatile bool running = false;
int first_buffer[2500];
Thread thread;
void file_active()
printf(“Opening /fs/tdgdeneme.txt \n”);
f = fopen(“/fs/tdgdeneme.txt”, “r+”);
if (!f)
printf("No file found, creating a new file...\n ");
fflush(stdout);
f = fopen("/fs/tdgdeneme.txt", "a+");
fseek(f, 0, SEEK_END);
void Inside_Root() // Display Root of the SD Card
int err;
// Display the root directory
printf(“Opening the root directory… “);
fflush(stdout);
DIR *d = opendir(”/fs/”);
printf(“%s\n”, (!d ? “Fail :(” : “OK”));
if (!d) {
error("error: %s (%d)\n", strerror(errno), -errno);
printf("Inside of the root directory:\n");
while (true) {
struct dirent *e = readdir(d);
if (!e) {
break;
printf(" %s\n", e->d_name);
printf("\nClosing the root directory... ");
fflush(stdout);
err = closedir(d);
printf("%s\n", (err < 0 ? "Fail :(" : "OK"));
if (err < 0) {
void Display_Folder()
// Display the tdg file
printf(“Opening "/fs/tdg.txt"… “);
fflush(stdout);
f = fopen(”/fs/tdg.txt”, “r”);
printf(“%s\n”, (!f ? “Fail :(” : “OK”));
if (!f) {
error(“error: %s (%d)\n”, strerror(errno), -errno);
printf("Inside of the Tdg.txt :\n\n");
while (!feof(f)) {
int c = fgetc(f);
printf("%c", c);
printf("\rClosing \"/fs/tdg.txt\"... ");
fflush(stdout);
err = fclose(f);
if (err < 0) {
void Write_to_SD()
{ // Open file
FILE *f = fopen(“/fs/tdgdeneme.txt”, “r+”);
if (!f) {
printf(“No file found, creating a new file…\n “);
fflush(stdout);
f = fopen(”/fs/tdgdeneme.txt”, “a+”);
fprintf(f, "Hello World! \n"); // Writing Data to the SD Card
fclose(f); // Close the file which also flushes any cached writes
int MountSd()
// Try to mount the filesystem
fflush(stdout);
err = fileSystem.mount(&blockDevice);
if (err) {
printf(“Failed to recognize SD card\n”);
return 0;
else{
return 1 ;
void TidyUp()
// Tidy up
fflush(stdout);
fileSystem.unmount(); //unmount device
fflush(stdout);
blockDevice.init();
fflush(stdout);
blockDevice.erase(0, blockDevice.size()); //erase block device
fflush(stdout);
blockDevice.deinit(); //deinitialize block device
void Threadprint(){
thread_sleep_for(1000);
MountSd();
printf(“Mount successful !\n”);
file_active();
int i = 0;
int b = 0;
while(true)
if(running)
for(i = 0 ; i<50 ; i++)
fprintf(f, "%d \n",first_buffer[b]); // Writing Data to the SD Card
b= b+1;
running = false;
printf(" -------- TDG -------- \n");
int old = 0;
int counter = 0;
running = false;
bool whilecond = true;
thread.start(Threadprint);
t.start();
while (whilecond)
timer_time = duration_cast<milliseconds>(t.elapsed_time()).count();
if(timer_time %4 == 0 && timer_time>old)
first_buffer[counter] = timer_time;
old = timer_time;
counter++;
if(counter %50 == 0)
running= true;
else if(counter >= 2500)
whilecond = false;
t.stop();
TidyUp();
for(int i=2400 ; i<2500 ; i++)
printf("%d\n",first_buffer[i]);
printf("\n -------- End of The Program -------- \n");
return 0;
