Adding ESP32 as a module
I have trouble adding ESP32 module to an nRF52840 based system. What I’m trying to do is adding the ESP32 module as a network interface to mbed and communicate via WiFi. The ESP is connected via UART connection.
As a build target I use NRF52840_DK and I can build and run firmware on it. However, I don’t get the ESP32 module working.
What I did so far:
  1. Added esp32-driver library (GitHub - ARMmbed/esp32-driver) to project. From the build output I can see that the library is compiled.
  2. I configured esp32-driver library for my build target in mbed_lib.json to assign the ESP32 pins to the correct pins on nRF52840 in the “target_overrides” block.
  3. I added “target.components_add” : [“esp32”] to my target in the “target_overrides” block in mbed_app.json
However, I always get the following message in debug output: Error! No network interface found.
Does anybody have any clue how to debug what’s going wrong here?
I’m pretty new to mbed OS and chances are that I’m missing something fundamentally.
Thank you,
Dominik
My guess is to add following line in your mbed_app.json.
"esp32.provide-default"                 : true,
Thank you MACRUM! I got it to work.
Here’s the target_overrides block in mbed_app.json I had to modify:
"target_overrides": {
            "nsapi.default-wifi-security": "WPA_WPA2",
            "nsapi.default-wifi-ssid": "\"SSID\"",
            "nsapi.default-wifi-password": "\"PASSWORD\"",
        "MY_TARGET": {
            "target.network-default-interface-type": "WIFI",
            "target.components_add" : ["esp32"],
            "esp32.provide-default": true
Do i have to create a newmbed_app.json and if so, in which folder should i put it? (the path)
Hi @Themis_Katis
The mbed_app.json file should be located in the root of your project folder.
