Hello folks,
I’d like to share my experience with adding libraries which are out-of-tree to an application program in mbed CLI2.
I had the following directory structure on a Linux machine and wanted to add the Clock library to the MyApp program.
/src
├── app
│ ├── os-2
│ └── os-6
| └──MyApp
| ├── main.cpp
| ├── CMakeLists.txt
| └── mbed-os (symbolic link to /src/sys/6.16.0)
├── lib
│ ├── os-2
│ └── os-6
| └──Clock
| ├── include
| | └── Clock.h
| └── source
| └── Clock.cpp
└── sys
├── 2.0.165
├── 6.15.1
├── 6.16.0
└── custom_targets
After a lot of struggle I came up with the following solution:
I created a CMakeLists.txt file in the Clock directory with the following content:
include_directories(
${CMAKE_CURRENT_LIST_DIR}/include
list(APPEND app_sources
${CMAKE_CURRENT_LIST_DIR}/source/Clock.cpp
And then I used the following CMakeLists.txt file in the MyApp directory:
# Copyright (c) 2022 ARM Limited. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
cmake_minimum_required(VERSION 3.19.0)
set(MBED_PATH ${CMAKE_CURRENT_SOURCE_DIR}/mbed-os CACHE INTERNAL "")
set(MBED_CONFIG_PATH ${CMAKE_CURRENT_BINARY_DIR} CACHE INTERNAL "")
set(APP_TARGET MyApp)
include(${MBED_PATH}/tools/cmake/app.cmake)
project(${APP_TARGET})
add_subdirectory(${MBED_PATH})
list(APPEND app_sources main.cpp)
include(/src/lib/os-6/Clock/CMakeLists.txt)
add_executable(${APP_TARGET} ${app_sources})
target_link_libraries(${APP_TARGET} mbed-os)
mbed_set_post_build(${APP_TARGET})
option(VERBOSE_BUILD "Have a verbose build process")
if(VERBOSE_BUILD)
set(CMAKE_VERBOSE_MAKEFILE ON)
endif()
This enables to easily add more libraries to the MyApp program by creating a similar CMakeLists.txt file in the given library’s directory and adding an additional line as below to the CMakeLists.txt file in the MyApp directory:
include(/src/lib/os-6/AnotherLibrary/CMakeLists.txt)
Maybe someone finds it useful.
Best regards,
Zoltan
