Hi community,
I am trying to track the voltage of a backup li-ion battery. Voltage is first divided into half via a resistor ladder and then fed into AnalogueIn on mbed (through 90mm trace on PCB, a bit too long probably). The readings via Bbed seems always 0.25 ~ 0.5V lower than actual readings by multimeter.
The following is my test. I repeatedly measure every 5 seconds. The first reading after downloading firmware is usually very close to actual, but starting from 2nd reading, it will drop and eventually quite lower than actual.
Is there anything I can do? It would be nice to not have readings so off.
AnalogIn Test Started with PoE and AC ADC:
1659344868: Current Voltage = 4156mv
1659344873: Current Voltage = 4127mv
1659344878: Current Voltage = 4043mv
1659344883: Current Voltage = 4045mv
1659344888: Current Voltage = 4050mv
1659344893: Current Voltage = 4045mv
1659344898: Current Voltage = 4051mv
1659344903: Current Voltage = 4043mv
1659344908: Current Voltage = 4047mv
1659344913: Current Voltage = 4048mv
1659344918: Current Voltage = 4045mv
