Incorrect voltage readings from LM35 and STM32 (blue pill)
Hi everyone,
I am having trouble reading the analog voltage on pin A0 of a stm32 blue pill board. The voltage being read is the v_out of a LM35 temperature sensor.
The first voltage that is displayed seems to be correct (the temperature is around 20-21 degrees in this room, thus a voltage of 210 mV is expected), but every following reading seems 100 mV off.
The code being used:
#include “mbed.h”
//Virtual serial port over USB
static BufferedSerial pc(PA_2,PA_3,9600);
AnalogIn LM35(A0);
DigitalOut Led(PC_13);
FileHandle *mbed::mbed_override_console(int fd)
    return &pc;
   float value;
   float analogval;
   LM35.set_reference_voltage(3.3);
   printf("Starting temperature reading:?\r\n");
   while(1) {
        analogval = LM35.read_voltage();
        value = analogval*3300/10;
        printf("Analogval: %d mV \r\n", int(analogval*1000));
        printf("Temp: %d degree C\r\n", int(floorf(value)));
        ThisThread::sleep_for(1s);
        Led =! Led;
The readings from the serial port:
Analogval: 211 mV
Temp: 69 degree C
Analogval: 91 mV
Temp: 30 degree C
Analogval: 96 mV
Temp: 31 degree C
Analogval: 99 mV
Temp: 32 degree C
I know that the conversion from volt to degrees is incorrect right now, but that is just a case of adding the right pre-multiplier. Also, I checked the voltage at vout with a multimeter and nothing seems wrong here (shows ~210 mV)
Does anyone have an idea what could be causing this behavior?
Best regards,
Yannick
I think I found the solution to the problem.
I added a 100nF capacitor and 1kohm resistor in series from the v_out to ground.
Now it displays the correct value in the serial monitor.
