Hi Yogesh,
Thanks for your response.
i am not enabled COAP BLOCKWISE feature and i am using the configuration of sample example with only changes of wifi user name and password…
yes it was working for payload of size less than 512 bytes.
one more observation after posting more than 512 bytes some times application was loosing network connection and not reconnecting.
[SMCC] Error occurred : MbedCloudClient::ConnectSecureConnectionFailed
[SMCC] Error code : 11
[SMCC] Error details : Client in reconnection mode SecureConnectionFailed
below was the log for greater than 512 bytes posted to a resource . i can clearly see the payload len as zero.
//sample code snippet where i set the hard coded value by calling setvalue.
payload_res->set_value((const char *)“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”);
[DBG ][mClt]: M2MReportHandler::set_notification_trigger(): 0
[DBG ][mClt]: M2MReportHandler::schedule_report()
[DBG ][mClt]: M2MReportHandler::report() - current 0.000000, last 1.000000, notify 1, queued 0
[DBG ][mClt]: M2MReportHandler::report()- send with VALUE change
[DBG ][mClt]: M2MNsdlInterface::observation_to_be_sent() uri 3336/0/5514
[INFO][mClt]: M2MNsdlInterface::send_resource_observation - uri 3336/0/5514
[INFO][mClt]: ======== Outgoing CoAP package ========
[INFO][mClt]: Status: COAP_STATUS_OK
[INFO][mClt]: Code: COAP_MSG_CODE_RESPONSE_CONTENT
[INFO][mClt]: Type: COAP_MSG_TYPE_CONFIRMABLE
[INFO][mClt]: Id: 48953
[INFO][mClt]: Token: 66:80:68:e2
[INFO][mClt]: Content-type: 0
[INFO][mClt]: Payload len: 0
[INFO][mClt]: Max-age: 0
[INFO][mClt]: Observe: 2
[INFO][mClt]: ======== End of CoAP package ========
[DBG ][mClt]: M2MNsdlInterface::send_to_server_callback(data size 12)
[DBG ][mClt]: M2MInterfaceImpl::coap_message_ready
[DBG ][mClt]: M2MInterfaceImpl::internal_event : new state 13
[DBG ][mClt]: M2MInterfaceImpl::state_engine
below was the call where i can see the payloan as 264
[INFO][mClt]: Id: 62729
[INFO][mClt]: Token: 41:75:50:47
[INFO][mClt]: Payload len: 264
A part from above logs some times i am able to observe the below errors in my trace logs
++++++++++++++++++++ Step 8. Update Data on Mbed Cloud ++++++++++++++++++++++++
Update cloud data With Payload : 9020b601400c53544d2d444953434f2d3031597e40100e00c0d801fe6794152fd0040000000040100e00c0d801fe6794154600000000000040100e00c0d801fe67941555fa8fca73bad240100e00c0d801fe679415592cdd96e16e3940100e00c0d801fe67941559ec080b0a020440100e00c0d801fe6794155e0c02050e0f0c40100e00c0d801fe679415609cd643d78af44226401e736c616d43616c63756c61746f722e43616c63756c617465456e61626c65410474727565
[DBG ][mClt]: M2MResourceBase::set_value()
[ERR ][coap]: sn_coap_protocol_linked_list_send_msg_store - failed to allocate message!
[DBG ][mClt]: M2MReportHandler::handle_timers()
[DBG ][mClt]: M2MResourceBase::report() - level 1
[DBG ][mClt]: M2MResourceBase::report() - combined level 1
[DBG ][mClt]: M2MResourceBase::report() - resource level
------------------------------ 2--------------------------------------------------------------------------
[INFO][esfs]: esfs_read - enter
[DBG ][PAAL]: arm_uc_paal_update.c:266: ARM_UCP_GetActiveFirmwareDetails
[DBG ][fcc ]: storage.c:441:storage_file_read_with_ctx:<===
[ERR ][PAAL]: arm_uc_pal_flashiap_implementation.c:696: unrecognized firmware header version
[INFO][fcc ]: key_config_manager.c:311:kcm_item_get_data:<=== kcm data size = 1
[ERR ][HUB ]: update_client_hub_state_machine.c:240: Firmware manager GetActiveFirmwareDetails failed error code ERR_NOT_READY
[DBG ][fcc ]: storage.c:360:storage_file_close:===>
[DBG ][HUB ]: update_client_hub_state_machine.c:322: ARM_UC_MONITOR_STATE_IDLE
-----------------------------------------3 -----------------------------------------------------------------------
[INFO][esfs]: esfs_file_size - enter
[DBG ][fcc ]: storage.c:410:storage_file_size_get_with_ctx:<===
[ERR ][fcc ]: storage.c:434:storage_file_read_with_ctx:<=== Buffer too small
[ERR ][fcc ]: key_config_manager.c:309:kcm_item_get_data:Failed reading file from storage (3)
DBG ][fcc ]: storage.c:258:storage_file_create:===> file_name_length=24
[INFO][esfs]: esfs_create - enter
[ERR ][esfs]: esfs_create() - pal_fsFopen() for working dir file failed
[ERR ][fcc ]: storage.c:283:storage_file_create:File already exist in ESFS (esfs_status 5)
[DBG ][fcc ]: storage.c:291:storage_file_create:<===
[INFO][fcc ]: key_config_manager.c:311:kcm_item_get_data:<=== kcm data size = 16
[ERR ][fcc ]: storage.c:131:storage_file_write:<=== Failed to create new file
[ERR ][fcc ]: key_config_manager.c:206:kcm_item_store:Failed writing file to storage
[INFO][esfs]: esfs_close - enter
[INFO][fcc ]: key_config_manager.c:210:kcm_item_store:<===
[DBG ][fcc ]: storage.c:369:storage_file_close:<===
[INFO][uccc]: ARM_UC_AddCertificate failed
---------------------4 --------------------------------------------------
[ERR ][fcc ]: fcc_dev_flow.c:96:fcc_developer_flow:<=== Store status: 8, Failed to store mbed.UseBootstrap
[SMCC] Developer credentials already exist
Praveen.Thota
