no function member for "attach " call in Ticker or Timeout. for X_PLC01A1 ST Microelectronics board in MBed Studio v 1.4.0
You probably mean this component/extension board - X-NUCLEO-PLC01A1 Programmable Logic Controller | Mbed
However your informations are weak
- MbedOS version?
- Target/board?
- A printscreen of the error would be nice
Ticker - API references and tutorials | Mbed OS 6 Documentation
Timeout - API references and tutorials | Mbed OS 6 Documentation
@semicon ,
What board are you connecting the X-NUCLEO-PLC01A1 to?
Try to replace
timeout.attach(this, &XNucleoPLC01A1::handle_freeze_to, msec/1000);
with
timeout.attach(callback(this, &XNucleoPLC01A1::handle_freeze_to), (std::chrono::microseconds)(msec*1000));
Since the second argument should be a time in microseconds the correct conversion from milliseconds to microseconds is msec*1000 rather than msec/1000.
the problem is the library is old and it was not updated for MbedOS 6+.
Two options:
- When you will follow what compiler says (errors) and check latest docs of Mbed Os you will found what is need to be changed.
- Downgrade the MbedOS to version 5.15 and use original.
Hello
could you please check the latest version of the library X_NUCLEO_PLC01A1 ?
Kind regards
Andrea
