zm1011
(m z)
February 17, 2016, 2:16pm
1
when I use like follow code ,it can’t operate correct. thank you!
#include “mbed-drivers/mbed.h”
#include “minar/minar.h”
#include “core-util/FunctionPointer.h”
using namespace mbed::util;
static DigitalOut led(LED1);
static void led_toggle_user(void) {
led = !led;
// printf(“LED = %d \r\n”, led.read());
static void led_toggle_irq(void) {
minar::Scheduler::postCallback(FunctionPointer0(&led_toggle_user).bind());
void app_start(int, char**) {
static Serial pc(USBTX, USBRX);
pc.attach(&led_toggle_irq);
led = 1;
while(true)
wait(5);
led = !led;
graghav
(Raghavendra Gade)
February 19, 2016, 9:40am
2
app_start in mbed is a minar event only, not like a main application. As the minar is a preemptive scheduler, we have to terminate an event to process another. so we should not use an infinte loop in app_start or any event. I hope that is the issue in your code.
refer the following link : GitHub - ARMmbed/minar: mbed OS scheduler
Thanks
zm1011
(m z)
February 22, 2016, 8:49am
3
when i remove the infinte loop the problem still exists. My purpose is receive uart message in mbedos ,what should i do ? thank you !!!
Kojto
(Martin Kojtal (0xc0170))
February 22, 2016, 1:18pm
4
there are not sufficient information provided.
what target are you using? yotta list - share the output, are all modules up to date?
You should not use static Serial pc(USBTX, USBRX);. If you want to use stdio Serial object, use :
/** Get the stdio Serial object, which is lazy instantiated.
* @returns stdio object
Serial& get_stdio_serial();
in the app:
Serial& pc = get_stdio_serial();
zm1011
(m z)
February 23, 2016, 1:19am
5
the follow code can run correct on frdm-k64f-gcc 2.0.0 ,but got frozen on st-nucleo-f401re-gcc 0.2.4 board ,if I want make 401 can also run the code which source should modified ? thanks !!!
#include "mbed-drivers/mbed.h"
#include "minar/minar.h"
#include "core-util/FunctionPointer.h"
static char buf [10];
//static DigitalOut led(YOTTA_CFG_HARDWARE_PINS_D4);
led =!led;
//pc.printf("receive");
buf[0]=pc.getc();
static void test(){
pc.printf(buf);
pc.attach(&led_toggle_user);
buf[0]='*';
buf[1]='\0';
led=1;
minar::Scheduler::postCallback(test).period(minar::milliseconds(500));
zm1011
(m z)
February 23, 2016, 1:23am
6
when I use target st-nucleo-f401re-gcc 0.2.4 board the code got frozen, but frdm-k64f-gcc 2.0.0 works well,my purpose is make 401 can run the code correct ,can you give me some hints please? thank you !!! (the code gives in above)
Kojto
February 23, 2016, 8:21am
7
Please don’t use static Serial pc(USBTX, USBRX) with mbed-drivers >= 0.12.x .Use the API shared above.
cc @bcostm
zm1011
(m z)
February 24, 2016, 1:42am
8
I want use serial communicate with other device ,not just USBTX/RX ,the API you shared above is just about USBTX,UBSRX pins ,right? -_-
zm1011
(m z)
February 24, 2016, 1:46am
9
I want use serial communicate with other device ,not just USBTX/RX ,the API you shared above is just about USBTX,UBSRX pins ,right? --@Kojto
yotta list output
_ mbed-drivers 0.12.1
| mbed-hal 1.2.2 yotta_modules\mbed-hal
| _ mbed-hal-st 1.0.0 yotta_modules\mbed-hal-st
| _ mbed-hal-st-stm32f4 1.1.2 yotta_modules\mbed-hal-st-stm32f4
| |_ uvisor-lib 1.0.12 yotta_modules\uvisor-lib
| |_ mbed-hal-st-stm32cubef4 1.0.2 yotta_modules\mbed-hal-st-stm32cubef4
| _ mbed-hal-st-stm32f401re 0.1.2 yotta_modules\mbed-hal-st-stm32f401re
|_ cmsis-core 1.1.2 yotta_modules\cmsis-core
| _ cmsis-core-st 1.0.0 yotta_modules\cmsis-core-st
| _ cmsis-core-stm32f4 1.0.5 yotta_modules\cmsis-core-stm32f4
| _ cmsis-core-stm32f401xe 0.1.0 yotta_modules\cmsis-core-stm32f401xe
|_ ualloc 1.0.3 yotta_modules\ualloc
| _ dlmalloc 1.0.0 yotta_modules\dlmalloc
|_ minar 1.0.4 yotta_modules\minar
| _ minar-platform 1.0.0 yotta_modules\minar-platform
| _ minar-platform-mbed 1.1.0 yotta_modules\minar-platform-mbed
|_ core-util 1.2.0 yotta_modules\core-util
_ compiler-polyfill 1.2.1 yotta_modules\compiler-polyfill
Kojto
February 24, 2016, 7:00am
10
Yes only for stdio. The above example defines Serial object for USBTX, RX
zm1011
(m z)
February 24, 2016, 7:58am
11
the mbed classic sdk can not run in mbed os 3.0? I just want migrate my project from mbed sdk to mbed os …
in my project just need serial ,can I remove minar module and just use main fun()? because the mbedos new feature for my project is not used.
