I am trying to enable Over the air updates using BLE on mbed-os for STM32WB55.
As a first step, i started with BLE_GattServer example at: https://github.com/ARMmbed/mbed-os-example-ble/tree/master/BLE_GattServer
I am trying to add MagicKeyValue as indicated in the document : AN5289 Section 7.5.7
For this i have modified the linker file as:
#if !defined(MBED_APP_START)
#define MBED_APP_START 0x08007000
#endif
#if !defined(MBED_APP_SIZE)
#define MBED_APP_SIZE 484K
#endif
#if !defined(MBED_BOOT_STACK_SIZE)
#define MBED_BOOT_STACK_SIZE 0x400
#endif
STACK_SIZE = MBED_BOOT_STACK_SIZE;
/* Linker script to configure memory regions. */
/* Total: 79 vectors = 316 bytes (0x13C) to be reserved in RAM1 (192K) */
MEMORY
FLASH (rx) : ORIGIN = MBED_APP_START, LENGTH = MBED_APP_SIZE
/*RAM1 (rwx) : ORIGIN = 0x2000013C + 0X04, LENGTH = 192K - 0x13C - 0X04 */
RAM1 (xrw) : ORIGIN = 0x20000004, LENGTH = 191k
RAM2a (rw) : ORIGIN = 0x20030000, LENGTH = 10K
RAM2b (rw) : ORIGIN = 0x20038000, LENGTH = 20K
/* Linker script to place sections and symbol values. Should be used together
* with other linker script that defines memory regions FLASH and RAM.
* It references following symbols, which must be defined in code:
* Reset_Handler : Entry of reset handler
* It defines following symbols, which code can use without definition:
* __exidx_start
* __exidx_end
* __etext
* __data_start__
* __preinit_array_start
* __preinit_array_end
* __init_array_start
* __init_array_end
* __fini_array_start
* __fini_array_end
* __data_end__
* __bss_start__
* __bss_end__
* __end__
* end
* __HeapLimit
* __StackLimit
* __StackTop
* __stack
* _estack
ENTRY(Reset_Handler)
SECTIONS
//ota_region 0x08087940:
.ota_region 0x08007140:
KEEP(*(TAG_OTA_START))
. = ALIGN(4);
} >FLASH
.text :
KEEP(*(.isr_vector))
*(.text*)
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*crtbegin?.o(.ctors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*crtbegin?.o(.dtors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata*)
KEEP(*(.eh_frame*))
} > FLASH
.ota_region_end :
. = ALIGN(4);
KEEP(*(TAG_OTA_END))
. = ALIGN(4);
} >FLASH
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > FLASH
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > FLASH
__exidx_end = .;
__etext = .;
_sidata = .;
.data : AT (__etext)
__data_start__ = .;
_sdata = .;
*(vtable)
*(.data*)
. = ALIGN(8);
/* preinit data */
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP(*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(8);
/* init data */
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(8);
/* finit data */
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
KEEP(*(.jcr*))
. = ALIGN(8);
/* All data end */
__data_end__ = .;
_edata = .;
} > RAM1
.bss :
. = ALIGN(4);
__bss_start__ = .;
_sbss = .;
*(.bss*)
*(COMMON)
. = ALIGN(4);
__bss_end__ = .;
_ebss = .;
} > RAM1
.heap (COPY):
__end__ = .;
end = __end__;
*(.heap*)
. = ORIGIN(RAM1) + LENGTH(RAM1) - STACK_SIZE;
__HeapLimit = .;
} > RAM1
/* .stack_dummy section doesn't contains any symbols. It is only
* used for linker to calculate size of stack sections, and assign
* values to stack symbols later */
.stack_dummy (COPY):
*(.stack*)
} > RAM1
.ble_stby_mem (NOLOAD) :
*(MAPPING_TABLE);
*(MB_MEM1);
} >RAM2a
.ble_shared_no_ret (NOLOAD) :
*(MB_MEM2);
} >RAM2b
/* Set stack top to end of RAM1, and stack limit move down by
* size of stack_dummy section */
__StackTop = ORIGIN(RAM1) + LENGTH(RAM1);
_estack = __StackTop;
__StackLimit = __StackTop - STACK_SIZE;
PROVIDE(__stack = __StackTop);
/* Check if data + heap + stack exceeds RAM1 limit */
ASSERT(__StackLimit >= __HeapLimit, "region RAM1 overflowed with stack")
TAG_OTA_END(NOLOAD) : { KEEP (*(TAG_OTA_END)) } >FLASH
Here I have added two sections TAG_OTA_START and TAG_OTA_END.
In my main.cpp, I add:
PLACE_IN_SECTION(“TAG_OTA_END”) const volatile uint32_t MagicKeywordValue = 0x94448A29 ;
PLACE_IN_SECTION(“TAG_OTA_START”) const volatile uint32_t MagicKeywordAddress = (uint32_t)(&MagicKeywordValue);
This means that at TAG_OTA_START an address is stored for the value of MagicKeywordValue
This should be stored at TAG_OTA_START at the end of code in flash.
- When I build and flash the bin file and check the device memory, I see the address of MagicKeywordValue stored at 0x08007140. When i check that address, i don’t see the MagicKeywordValue. When I add offset of 0x140 to the address stored at 0x08007140, I see the MagicKeywordValue offset by an additional 8 bytes.
Can somebody tell me why is the value stored at address offseted by 0x140 + 8bytes?
