I am following the instructions to setup mbed for the PSoC prototyping kit at Cypress products with Mbed OS - | Mbed
I am using Cygwin64 and get the following error complaining that Python.h could not be found. The Python development package is installed and the include path in the gcc command points to the correct location, highlighted below. I am a bit frustrated as I had to install a bunch of extra packages in Cygwin to get even this far.
I appreciate any help.
$ pip3 install --upgrade pip ‘mbed-ls>=1.7.1’ ‘pyocd>=0.16’
Requirement already up-to-date: pip in /usr/lib/python3.6/site-packages (20.2.2)
Collecting mbed-ls>=1.7.1
Using cached mbed-ls-1.7.12.tar.gz (174 kB)
Collecting pyocd>=0.16
Using cached pyocd-0.27.2-py2.py3-none-any.whl (7.7 MB)
Collecting PrettyTable>=0.7.2
Using cached prettytable-0.7.2.tar.bz2 (21 kB)
Collecting mbed-os-tools<0.1.0,>=0.0.9
Using cached mbed-os-tools-0.0.15.tar.gz (286 kB)
Collecting colorama
Using cached colorama-0.4.3-py2.py3-none-any.whl (15 kB)
Collecting pylink-square
Using cached pylink_square-0.6.1-py2.py3-none-any.whl (75 kB)
Collecting six<2.0,>=1.0
Using cached six-1.15.0-py2.py3-none-any.whl (10 kB)
Collecting cmsis-pack-manager>=0.2.7
Using cached cmsis-pack-manager-0.2.10.tar.gz (45 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3.6 -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-3w03u50t/cmsis-pack-manager/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-3w03u50t/cmsis-pack-manager/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ egg_info --egg-base /tmp/pip-pip-egg-info-5_2251up
cwd: /tmp/pip-install-3w03u50t/cmsis-pack-manager/
Complete output (71 lines):
command: /usr/bin/python3.6 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '”‘"’/tmp/pip-wheel-z3_iqwl6/cffi/setup.py’“'”‘; file=’“'”‘/tmp/pip-wheel-z3_iqwl6/cffi/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-bm6ilgln
cwd: /tmp/pip-wheel-z3_iqwl6/cffi/
Complete output (34 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.cygwin-3.1.6-x86_64-3.6
creating build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/api.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/backend_ctypes.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/cffi_opcode.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/commontypes.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/cparser.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/error.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/ffiplatform.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/lock.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/model.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/pkgconfig.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/recompiler.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/setuptools_ext.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/vengine_cpy.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/vengine_gen.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/verifier.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/init.py → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/_cffi_include.h → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/parse_c_type.h → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/_embedding.h → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
copying cffi/_cffi_errors.h → build/lib.cygwin-3.1.6-x86_64-3.6/cffi
running build_ext
building ‘_cffi_backend’ extension
creating build/temp.cygwin-3.1.6-x86_64-3.6
creating build/temp.cygwin-3.1.6-x86_64-3.6/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -ggdb -O2 -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector-strong --param=ssp-buffer-size=4 -fdebug-prefix-map=/pub/devel/python/python36/python36-3.6.10-1.x86_64/build=/usr/src/debug/python36-3.6.10-1 -fdebug-prefix-map=/pub/devel/python/python36/python36-3.6.10-1.x86_64/src/Python-3.6.10=/usr/src/debug/python36-3.6.10-1 -ggdb -O2 -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector-strong --param=ssp-buffer-size=4 -fdebug-prefix-map=/pub/devel/python/python36/python36-3.6.10-1.x86_64/build=/usr/src/debug/python36-3.6.10-1 -fdebug-prefix-map=/pub/devel/python/python36/python36-3.6.10-1.x86_64/src/Python-3.6.10=/usr/src/debug/python36-3.6.10-1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.6m -c c/_cffi_backend.c -o build/temp.cygwin-3.1.6-x86_64-3.6/c/_cffi_backend.o
c/_cffi_backend.c:2:20: fatal error: Python.h: No such file or directory
compilation terminated.
error: command ‘gcc’ failed with exit status 1
ERROR: Failed building wheel for cffi
ERROR: Failed to build one or more wheels
File “/usr/lib/python3.6/site-packages/setuptools/installer.py”, line 128, in fetch_build_egg
subprocess.check_call(cmd)
File “/usr/lib/python3.6/subprocess.py”, line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[’/usr/bin/python3.6’, ‘-m’, ‘pip’, ‘–disable-pip-version-check’, ‘wheel’, ‘–no-deps’, ‘-w’, ‘/tmp/tmpagjqkq6n’, ‘–quiet’, ‘cffi>=1.6.0’]’ returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "/tmp/pip-install-3w03u50t/cmsis-pack-manager/setup.py", line 73, in <module>
test_suite="tests"
File "/usr/lib/python3.6/site-packages/setuptools/__init__.py", line 143, in setup
_install_setup_requires(attrs)
File "/usr/lib/python3.6/site-packages/setuptools/__init__.py", line 138, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/lib/python3.6/site-packages/setuptools/dist.py", line 698, in fetch_build_eggs
replace_conflicting=True,
File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 783, in resolve
replace_conflicting=replace_conflicting
File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 1066, in best_match
return self.obtain(req, installer)
File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 1078, in obtain
return installer(requirement)
File "/usr/lib/python3.6/site-packages/setuptools/dist.py", line 754, in fetch_build_egg
return fetch_build_egg(self, req)
File "/usr/lib/python3.6/site-packages/setuptools/installer.py", line 130, in fetch_build_egg
raise DistutilsError(str(e))
distutils.errors.DistutilsError: Command '['/usr/bin/python3.6', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpagjqkq6n', '--quiet', 'cffi>=1.6.0']' returned non-zero exit status 1.
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
