Is it possible to make a callback to a member function with arguments. Is there any preferred “workaround” if not possible?
For example (just for illustration, not necessarily complete nor compilable):
void function1(int *somearg) {
// do something with somearg
class Example {
private:
Thread *_pExampleThread;
void function2() {
// do something with.... uhh... nothing?
void function_wanted(int *somearg) {
public:
void setup1(int exposed_arg) {
// this works, but calls static func
_pExampleThread->start(callback(function1, &exposed_arg));
void setup2(int exposed_arg) {
// this also works, but takes no args
_pExampleThread->start(callback(this, &Example::function2));
void setup_wanted(int exposed_arg) {
// how to make something like this work?
_pExampleThread->start(callback(this, &Example::function_wanted, &exposed_arg));
I think I can’t use global vars or similar workaround since there’s possibility the (member) function is called multiple times.
Is it possible to make a callback to a member function with arguments?
If the member function is static it is possible to pass one argument to the callback function in Thread’s start method.
For example:
class Example {
private:
static void function_wanted(int *somearg) {
public:
_pExampleThread->start(callback(&Example::function_wanted, &exposed_arg));
