I am using the arm_math.h library to build my first FFT spectrum analyser. I’ve used the instructions in this thread too import the mbed-dsp libraries. When I compile my program, it fails at 12% with the following message:
[Error] main.cpp@78,5: no matching function for call to ‘arm_rfft_fast_f32’
[ERROR] .\main.cpp:78:5: error: no matching function for call to ‘arm_rfft_fast_f32’
arm_rfft_fast_f32(&fft_handler, &FFT_inputBuffer, &FFT_outputBuffer, 0);
./mbed-dsp/cmsis_dsp\arm_math.h:2233:6: note: candidate function not viable: no known conversion from ‘float (*)[2048]’ to ‘float32_t *’ (aka ‘float *’) for 2nd argument; remove &
void arm_rfft_fast_f32(
1 error generated.
This is a curious error as when I begin to type “arm_rfft…” MBED Studio offers an auto fill as such : “arm_rfft_fast_f32(arm_rfft_fast_instance_f32 *S, float32_t *p, float32_t *pOut, uint8_t ifftFlag)” , which suggests that there is indeed a function of that name and parameters included in my program. The compiler also seems to not like my use of pointers, suggesting that I remove the ‘&’. Following this advice, I am still met with the following erros:
arm_rfft_fast_f32(fft_handler, FFT_inputBuffer, FFT_outputBuffer, 0);
./mbed-dsp/cmsis_dsp\arm_math.h:2233:6: note: candidate function not viable: no known conversion from ‘arm_rfft_fast_instance_f32’ to ‘arm_rfft_fast_instance_f32 *’ for 1st argument; take the address of the argument with &
1 error generated.
I have posted my code on GitHub so that you may have a closer inspection of my work.
Many thanks,
Andy
