I’m using mbed-http library for some basic http(s) request-response project. Compiler gives me this error code Error: Class "Socket" has no member "send" in "mbed-http/source/http_request_base.h", Line: 270, Col: 59 I have TCPSocket included do I need to import some sort of other Socket library?
The program will run on Nucleo-F746ZG.
Thanks for your help!
it would be good also include a link to the library or program what you use.
How I remember, the HTTP is obsolete for using it with the latest Mbed OS5, so it is recommended to use an example in its origin state or with an old Mbed lib (MbedOS 5.10).
It is this library http-example - HTTP and HTTPS example application for Mbed OS 5 | Mbed
Is there any good alternative you know of?
How I said, when you will not update the Mbed Os library to newest version, the example will work I think.
However, you can check other questions with same/similar Issue.
- Any suggestion for mbed HTTP library (mbed-http not work with recent mbed-os)
- Webserver with WebSockets für mbed-os5
