I am trying to connect a small vibration motor to FRDM K64F. However, only port PTA1 and PTA2 works, and it doesn’t work for any other port (such PTC4 …).
I am using more than two motors, so I need to use ports other than PTA1,2.
below is the mbed code:
I do not know, it was only my tip, maybe I am total out but when I tried to ask Google about “Current of mobile vibration motor”, I found something about 70mA and I think that is too much. Also will be here probably a current spike at the start.
I think you need to control the motors via transistors and from different power supply instead of the onboard one.
About the ports. Nope I not think the PortA gives more power, but you set these pins to 1 as first and boards have usually a overcurrent protection/management or something like that.
It leads me to your claim “When I connect an LED across the 4 ports, it works for all of them”
I have used a transistor with the inboard 3.3V, and it works perfectly.
emitter connected to 3.3v
base to pin PT…
collecter to motor.
This seems to be the only way to make it work.
