Hi all,
after setup openOCD, and debug profile and this tutorial for Eclipse Debug + with this settings
I have this error
16:11:08 **** Incremental Build of configuration Default for project mbed-os-example-mbed5-blinky ****
make -j
"Compile: main.cpp"
"Compile: RTX_Config.c"
"Compile: cmsis_os1.c"
"Assemble: irq_cm4f.S"
"Compile: rtx_delay.c"
"Compile: rtx_evflags.c"
arm-none-eabi-g++: error: library: No such file or directory
arm-none-eabi-g++: error: folder/mbed_os-trainy/mbed-os: No such file or directory
arm-none-eabi-gcc: error: library: No such file or directory
arm-none-eabi-gcc: error: folder/mbed_os-trainy/mbed-os: No such file or directory
arm-none-eabi-gcc: error: folder\mbed_os-trainy\mbed-os: No such file or directory
"Compile: rtx_evr.c"
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1965: main.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1960: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Config/RTX_Config.o] Error 1
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1960: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Library/cmsis_os1.o] Error 1
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1953: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/TOOLCHAIN_GCC/TARGET_RTOS_M4_M7/irq_cm4f.o] Error 1
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1960: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/rtx_delay.o] Error 1
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1960: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/rtx_evflags.o] Error 1
make[1]: *** [C:/Users/kravcikm/Documents/mbed folder/mbed_os-trainy/Makefile:1960: mbed-os/cmsis/CMSIS_5/CMSIS/RTOS2/RTX/Source/rtx_evr.o] Error 1
make: *** [Makefile:26: all] Error 2
"make -j" terminated with exit code 2. Build might be incomplete.
16:11:09 Build Failed. 9 errors, 0 warnings. (took 1s.333ms)
I can’t understand why it is use make -j, what is obliviously problem.
Shall I change something? build woks perfect with mbed CLI. Why make is here, i dont know.
Thanks for any ideas.
