Debug build profile fails
Hello there,
I was using my program and I was compiling successfully with the Debug build profile (the program is running in a custom made stm32l0xx board and a custom target). Now if I compile the same program in Develop or Release mode is working while in Debug it returns an eeprom problem (without changing anything).
I couldn’t find a reason for that, I wanted to use debug profile so I could use “mbed_debug.h” and debug(“”); library instead of printf and save some memory space in the release version.
Is there any known bug?
Best Regards,
Rafaella
Hi Rafaella,
It sounds like the code size exceeding the limitation. To check the map file and try to reduce some functions.
Desmond
So, we fixed this issue. It was actually a hardware issue. The errors reading/writing to the EEPROM were caused by a dry joint on an I2C pullup resistor.
