Hi, I’m totally Novice in using Electronic board and online IDE. Hope you get the issue I mentioned.
I’ve STM32L101RB board, I logged in to mbed site to execute my first program but faced difficulties and unable to find the solution. Problems are as follows:-
In the Keil Studio cloud checks the Target hardware combobox. Before name of your target is USB logo and a exclamation mark in a circle. When you palce your mouse above that you will see dialog with an info - your target is not supported with the active project's version of MbedOS.
However I can not found any information about STM32L010 on Mbed web, so it seems like it was never supported in the past.
One similar is - NUCLEO-L011K4 | Mbed which was supported in Mbed2 and MbedOS 5 and them was dropped.
Thank you for quick reply and valuable info .
I logged out and logged in Old Online Compiler but problem remain same.
For Keil Studio Compiler , what you said is correct target is not supported.
I watched youtube and there they mentioned “Keil Micro Vision 5”, but while creating new project I saw stm32 option is missing from microcontroller section only ARM is mentioned.
I installed stm32 Cube IDE , as a beginner I felt there syntax of coding is different .
I think need to wander more to get the proper solution.
Thanks again for your valuable reply.
