When using MBedOS in SAMR34 Xplained Pro with the following LoRa configuration I am facing the issue with disabling ADR in OTAA method and setting the desired Data Rate for LoRa Transmissions
Configuration used::
- Transmission Type : OTAA
- ADR : Disabled
- Data Rate : Set to DR_0
- Delay B/W Transmissions : 0
- Frequency Band : IN865
- Payload Size : 10Bytes
- N/W server : Chirp Stack (ADR is disabled in N/W server-side)
Observations we got::
- Uplinks packets are received with DR_5 even we set DR_0
- When used ABP method ADR is disabled and uplinks are received at DR_0 as expected
How can we address this issue of disabling ADR in the OTAA method
