DMA for LPC1768 with Mbed OS 6
Hello folks,
Those who are interested in using DMA (Direct Memory Access) on LPC1768 mbed boards with Mbed OS 6 please find a fork of Andy Kirkham’s MODDMA library here.
Below is an example of comparing DMA speed with memcpy.
#include "MODDMA.h"
DigitalOut  led1(LED1);
MODDMA      dma;
int         transferState = 0;
Timer       timer;
// Create a source buffer we are going to move.
static char src[16*1024-1] __attribute__((section("AHBSRAM0")));
// Create a buffer for the destination to copy to.
static char dst[sizeof(src)] __attribute__((section("AHBSRAM1")));
 * @brief
 * @note
 * @param
 * @retval
void myCallback(void)
    transferState = 1;
 * @brief
 * @note
 * @param
 * @retval
    timer.start();
    // Transfer/copy src content to dst using the memcpy function
    memcpy(dst, src, sizeof(src));
    timer.stop();
    printf("It took %lli us to transfer %i bytes using memcpy\r\n", timer.elapsed_time(), sizeof(src));
    // Create a MODDMA configuration object.
    MODDMA_Config*  conf = new MODDMA_Config;
    // Setup that configuration
    conf->channelNum(MODDMA::Channel_0);
    conf->srcMemAddr((uint32_t) & src);
    conf->dstMemAddr((uint32_t) & dst);
    conf->transferSize(sizeof(src));
    conf->transferType(MODDMA::m2m);
    conf->attach_tc(&myCallback);
    // config end
    // Pass the configuration to the controller
    dma.Setup(conf);
    timer.reset();
    timer.start();
    // Tell the controller to perform the DMA operation
    // defined by that configuration.
    dma.Enable(conf);
    while (transferState == 0); // wait for DMA transfer to be completed
    timer.stop();
    printf("It took %lli us to transfer %i bytes using DMA\r\n", timer.elapsed_time(), sizeof(src));
    while (1) {
        led1 = !led1;
        ThisThread::sleep_for(500ms);
Printout:
It took 1204 us to transfer 16383 bytes using memcpy.
It took 96 us to transfer 16383 bytes using DMA.
Did anyone managed to get MODDMA compiling in PlatformIO? The compiler seems different and has severe issues with the source code (starts with the Init() & Setup() having no implementation).
